using toggle switch
hello i have toggle switch like MTS-203
and i want to count with toggle switch
this is code that i make
const int toggle1 = 8;
const int toggle2 = 9;
volatile byte count1;
volatile byte count2;
pinMode(toggle1,INPUT);
pinMode(toggle2,INPUT);
count1 = 0;
count2 = 0;
if (digitalRead(toggle1)==LOW) {
count1++;
if (digitalRead(toggle2)==LOW) {
count2++;
Serial.print("count1 = ");
Serial.println(count1,DEC);
Serial.print("count2 = ");
Serial.println(count2,DEC);
and this is my board
and then that is Execution window
i wonder what’s matter
please give me help
When the switch is to the right, as in your diagram, how do you know what the voltage is on the left hand pin ?
You need a pull up resistor on each pin (8 & 9) to 3.3 or 5 volts (what ever the due takes).
