Using togheter librarys VarSpeedServo.h and ClickEncoder.h
I am trying to use library VarSpeedServo.h and ClickEncoder.h. As soon as I attaches the servo on pin the encoder stops working.
Can please someone look my code to see what i am doing wrong?
My code:
#define WITH_LCD 1
#define TEST 1
//#ifdef TEST
//#endif
// Include NewLiquidCrystal Library for I2C
#include <ClickEncoder.h>
#include <TimerOne.h>
#include <VarSpeedServo.h>
VarSpeedServo myservo;    // create servo object to control a servo
int16_t oldPosition  = -9999;
int16_t newPosition;
// Define LCD pinout
const int  en = 2, rw = 1, rs = 0, d4 = 4, d5 = 5, d6 = 6, d7 = 7, bl = 3;
// Define I2C Address - change if reqiuired
const int i2c_addr = 0x27;
 // Define LCD display connections
LiquidCrystal_I2C lcd(i2c_addr, en, rw, rs, d4, d5, d6, d7, bl, POSITIVE);
#define LCD_CHARS   20
#define LCD_LINES    4
ClickEncoder *encoder;
int16_t last, value;
void timerIsr() {
  encoder->service();
#ifdef WITH_LCD
void displayAccelerationStatus() {
  lcd.setCursor(0, 1);
  lcd.print("Acceleration ");
  lcd.print(encoder->getAccelerationEnabled() ? "on " : "off");
#endif
  encoder = new ClickEncoder(A1, A0, A2);
   myservo.attach(9);  // attaches the servo on pin 9 to the servo object
#ifdef WITH_LCD
  lcd.begin(LCD_CHARS, LCD_LINES);
  lcd.clear();
  displayAccelerationStatus();
#endif
  Timer1.initialize(1000);
  Timer1.attachInterrupt(timerIsr);
  last = -1;
  value += encoder->getValue();
  if (value != last) {
    last = value;
    Serial.print("Encoder Value: ");
    Serial.println(value);
#ifdef WITH_LCD
    lcd.setCursor(0, 0);
    lcd.print("         ");
    lcd.print(value);
#endif
  myservo.write(value, 30, true);        // move to 180 degrees, use a speed of 30, wait until move is complete
  ClickEncoder::Button b = encoder->getButton();
  if (b != ClickEncoder::Open) {
    Serial.print("Button: ");
    #define VERBOSECASE(label) case label: Serial.println(#label); break;
    switch (b) {
      VERBOSECASE(ClickEncoder::Pressed);
      VERBOSECASE(ClickEncoder::Held)
      VERBOSECASE(ClickEncoder::Released)
      VERBOSECASE(ClickEncoder::Clicked)
      case ClickEncoder::DoubleClicked:
          Serial.println("ClickEncoder::DoubleClicked");
          encoder->setAccelerationEnabled(!encoder->getAccelerationEnabled());
          Serial.print("  Acceleration is ");
          Serial.println((encoder->getAccelerationEnabled()) ? "enabled" : "disabled");
#ifdef WITH_LCD
#endif
On a UNO both libraries ( VarSpeedServo.h and ClickEncoder.h) will use Timer 1 - creating a conflict
On a more capable hardware you could define which timer is used (see the VarSpeedServo.h) or use other servo libraries or deal with your encoder differently
Please correct your post above and add code tags around your code:
[code]`` [color=blue]// your code is here[/color] ``[/code].
It should look like this:// your code is here
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
Thanks!
I will try to study timers for weekend :slight_smile:
Best regards,
Borut
