Using TouchBoard and mp3 sounds + graphing
Can anyone tell me, by looking at the below code, what I might need to do in order to get these 2 routines called within the "void loop" to play nicely together?
void loop(){
readTouchInputs();
readRawInputs();
Basically, I can do one call, or the other, but not both. I think there's a comflict with the MPR121.updateTouchData(); call and the MPR121.updateAll();
A little bit of background - - - I'm basically trying to modify Bareconductive's Touchboard to play mp3's when touched AND pass proximity-data back to Bareconductive's graphing software. The mp3 routine is the "readTouchInputs()" routine, and the "pass data to the graphing software" routine is the "readRawInputs" call. I'm finding that I can do one, or the other, but doing both is unreliable. From what I can tell, mp3's will play, but only about 10% of the time - - - I suspect that the loop is getting bogged down with the MPR121.updateAll() calls. Perhaps if there's some way to only perform the calls X number of times a second?
Any advice is greatly appreciated.
// compiler error handling
#include "Compiler_Errors.h"
// touch includes
#include <MPR121.h>
#include <Wire.h>
#define MPR121_ADDR 0x5C
#define MPR121_INT 4
// mp3 includes
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <SFEMP3Shield.h>
// mp3 variables
SFEMP3Shield MP3player;
byte result;
int lastPlayed = 0;
// touch behaviour definitions
#define firstPin 0
#define lastPin 11
// sd card instantiation
SdFat sd;
// define LED_BUILTIN for older versions of Arduino
#ifndef LED_BUILTIN
#define LED_BUILTIN 13
#endif
void setup(){
  Serial.begin(57600);
  pinMode(LED_BUILTIN, OUTPUT);
  //while (!Serial) ; {} //uncomment when using the serial monitor
  Serial.println("Bare Conductive Touch MP3 player");
  if(!sd.begin(SD_SEL, SPI_HALF_SPEED)) sd.initErrorHalt();
  if(!MPR121.begin(MPR121_ADDR)) Serial.println("error setting up MPR121");
  MPR121.setInterruptPin(MPR121_INT);
  result = MP3player.begin();
  MP3player.setVolume(10,10);
  if(result != 0) {
    Serial.print("Error code: ");
    Serial.print(result);
    Serial.println(" when trying to start MP3 player");
void loop(){
  readTouchInputs();
  readRawInputs();
void readTouchInputs(){
  if(MPR121.touchStatusChanged()){
    // only make an action if we have one or fewer pins touched
    // ignore multiple touches
    if(MPR121.getNumTouches()<=1){
      for (int i=0; i < 12; i++){  // Check which electrodes were pressed
        if(MPR121.isNewTouch(i)){
            //pin i was just touched
            Serial.print("pin ");
            Serial.print(i);
            Serial.println(" was just touched");
            digitalWrite(LED_BUILTIN, HIGH);
            if(i<=lastPin && i>=firstPin){
              if(MP3player.isPlaying()){
                if(lastPlayed==i){
                  // if we're already playing the requested track, stop it
                  MP3player.stopTrack();
                  Serial.print("stopping track ");
                  Serial.println(i-firstPin);
                  // if we're already playing a different track, stop that
                  // one and play the newly requested one
                  MP3player.playTrack(i-firstPin);
                  Serial.print("playing track ");
                  // don't forget to update lastPlayed - without it we don't
                  // have a history
                  lastPlayed = i;
                // if we're playing nothing, play the requested track
                // and update lastplayed
                lastPlayed = i;
        }else{
          if(MPR121.isNewRelease(i)){
            Serial.print(i);
            Serial.println(" is no longer being touched");
            digitalWrite(LED_BUILTIN, LOW);
void readRawInputs(){
    int i;
    MPR121.updateAll();
    Serial.print("TOUCH: ");
    for(i=0; i<13; i++){          // 13 touch values
      Serial.print(MPR121.getTouchData(i), DEC);
      if(i<12) Serial.print(" ");
    Serial.print("TTHS: ");
    for(i=0; i<13; i++){          // 13 touch thresholds
      Serial.print(MPR121.getTouchThreshold(i), DEC);
    Serial.print("RTHS: ");
    for(i=0; i<13; i++){          // 13 release thresholds
      Serial.print(MPR121.getReleaseThreshold(i), DEC);
    Serial.print("FDAT: ");
    for(i=0; i<13; i++){          // 13 filtered values
      Serial.print(MPR121.getFilteredData(i), DEC);
    Serial.print("BVAL: ");
    for(i=0; i<13; i++){          // 13 baseline values
      Serial.print(MPR121.getBaselineData(i), DEC);
    // the trigger and threshold values refer to the difference between
    // the filtered data and the running baseline - see p13 of
    // http://www.freescale.com/files/sensors/doc/data_sheet/MPR121.pdf
    Serial.print("DIFF: ");
    for(i=0; i<13; i++){          // 13 value pairs
      Serial.print(MPR121.getBaselineData(i)-MPR121.getFilteredData(i), DEC);
First, you don't have a "void loop". You have a FUNCTION called loop.
What do they do now?
You might as well rename that function doABunchOfStuff() for all the relationship there is between reading touch inputs and playing mp3 tracks.
Aha, the doSomeOtherStuff() function rears its ugly head.
A function should do what its name says it does AND NOTHING MORE AND NOTHING LESS.
When your functions do no more, and no less, than the name implies, I'll be more inclined to look at what they actually do.
