After using 74HC595 Shift registers and ULN2803’s for a while (though not always correctly XD ) I am now trying to now use the TPIC6B595 Shift registers with SPI. I have attached an image of my circuit and here is the basic code that I am starting with. I have kept the code simple until I understand how to drive the chip correctly, Can someone please tell me what I might be doing wrong because it is not working correctly. Also, I assume that the zero’s in my “digit” byte are the ones that are controlling the grounds that will light the appropriate LED’s,
Thanks Pedro.
I as a databit in makes the output go low to sink cathode current, same as if driving ULN2803.
SRCLR is typically tied to 5, and OE/ tied to Gnd.
Output will appear erratic if these 2 pins are left floating.
Delete these - SPI library takes care of them #define dataPin 11 // MOSI #define clockPin 13 // SPI SCLK
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
All GNDs must be connected.
Put a 0.1uF cap from Vcc to Gnd.
Crossroads, when you say “SRCLR is typically tied to 5 “ presumably SRCLR means pin 8 of the 595, and what does “tied to 5” mean?
And OE (output enable?) is pin ? of the SR ?
Sorry for my ignorance but I still find that there are quite a few different names for some of the pins of these IC’s
EDIT - I worked it out Tied to 5 meant SRCLR (Pin 8 of 595) to + 5V
OE is pin 9 (G overscore) of 595 to ground.
Thanks again Crossroads 8) easy when you know how
@crossroads I configured a TPIC6b595 on a circuitboard with only pin 10 connected to GND (lower left corner given half-moon at the top) and the other GND pins unconnected. Is this a problem? What consequences might I observe and should I fix the design or is it just a nice-to-have with each GND connected to a common plane?
Currently the circuit seems to be acting as it should, but perhaps there's a failure mode associated with not having them all grounded.
By the by, overscore G is also connected for logic reasons to GND, in case my statement above is misleading.
