Logic (ESP32s, SD, GPS): ~0.3 to 0.5 A using ESPNow Protocol
Servos: normal movement ~150–250 mA each, stall ~600–800 mA each
Worst case: all 3 servos stall at once + logic load → ~2.5–3 A peak
The 5 V rail comes from a 3000mAh 7.4V battery that is step down to 5V and 3.3V, and I also have a 3.3 V rail for some logic, all components share the same ground.
I’m thinking of adding a TPS2596 eFuse on the 5 V rail so that if any device (likely the servos) tries to pull more than the set maximum current, the eFuse will protect the rest of the system.
Questions:
Is putting a single TPS2596 on the whole 5 V rail a good idea, or should I split the logic and servo rails with separate eFuses?
What’s a reasonable ILIM setting for the TPS2596 in this setup, considering servo stall currents but avoiding brown-outs on the ESP32s?
Any tips for wiring, decoupling, or dV/dt settings to avoid nuisance trips?
When I use fuses, I have a main fuse at the battery then smaller fuses for things like motors etc.
You should plan some sort of fuse coordination in your design.
You can look at fold-back current limiting also.
Fusing often protects wiring and the battery, components is a whole there story
Fusing is good, but you also have to consider whether it will respond fast enough to protect your parts. I use fuses to protect the wiring, not the device. In many projects, I simply depend on the power supply to limit the current. The ones I use generally fold back and are adjustable.
Thanks, I do agree on fuse coordination and a main fuse at the battery.
I guess my goals are as such:
Protect wiring/battery from shorts (classic fuse job).
Keep the ESP32s up when a servo stalls (active limiting so the logic devices are not damaged).
Maybe a hybrid approach?
Main fuse at the 2S Li-ion battery to protect wiring.
Split 5 V into two branches:
• Logic branch (ESP32s, SD, GPS): lower current limit.
• Servo branch (3× SG90): higher current limit.
Use an eFuse (TPS2596) per branch for active current limiting + inrush control so a servo stall trips only the servo branch instead of collapsing the whole 5 V rail.
Optional PTC/SMD fuse per servo as sacrificial protection if stalls are common.
On fold-back current limiting I can see how it would be very useful for protecting logic devices since they aren’t expected to draw large currents at low voltages. However, if fold-back was added on the servo branch, my concern is that it could end up stalling the servos whenever they are already pulling high current to move under load. In those cases, reducing the available current even further would make it harder for the servo to overcome the load and could cause unintended stalls. What do you think on this matter?
Hi all, I posted earlier asking help here is the link to the previous query Initial Query
I would like to thank the community for the help i received earlier and would like to provide an update. I’ve designed the attached circuit and would like some genuine feedback on its robustness and possible improvements before I commit to a PCB.
Overview:
Power source: main 5 V and 3.3 V line from a buck converter (fed by a 7.4V 3000mAh 2S Li-ion pack).
Passes through a TPS25962 eFuse (auto-retry version) with:
Undervoltage lockout (UVLO): 4.8 V rising / ~4.6 V falling.
Overvoltage lockout (OVLO): 5.7 V.
ILIM: ~1 A via 909 Ω resistor.
dV/dt soft-start: 2.2 nF.
FLT pin drives an LED for fault indication.
Servo rail protection:
Each servo V+ passes through an individual PTC fuse (Littelfuse 1206L050YR, I_hold 0.5 A, I_trip 1 A).
No active current limiting—PTCs intended to trip on sustained stall or short.
My main goals:
Prevent servo stall/short events from damaging the logic rail.
Keep ESP32 and other logic devices safe under supply anomalies (UV/OV).
Provide some fault indication and graceful recovery.
Questions for the community:
Does the overall split-rail + eFuse/PTC approach look robust for mixed logic + servo loads?
Are the UVLO/OVLO thresholds chosen appropriately for 5 V logic? Would you tweak them?
Are there improvements you’d suggest for noise suppression between the rails?
On the servo side, are the 0.5 A hold PTCs the right balance between protection and avoiding nuisance trips for SG90s?
Any other obvious improvements for reliability, noise immunity, or protection that I’ve overlooked?
I’d really appreciate any constructive suggestions as this project is intended for a rather simple model satellite using LoRA communication and an SD Card module for data logging
Your two or more topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thanks for the feedback. I’ve made the following updates based on the suggestions:
Added a ceramic capacitor at both the input and the output plus at least one aluminum polymer capacitor at the output.
Added the bypass from the circuit protection section as suggested and yeah I agree, this is great to have in case I need to bypass the eFuse in troubleshooting or in emergencies.
For the FLT pin (Pin 6) honestly great find on the maximum sink current being 10 mA. I didn’t connect it to the ESP32 but I did increase the LED series resistor to 1.5 kΩ to keep the current safe.
I might cut down to one bulk capacitor later due to limited board space but I’ve left both in for now.
You’re absolutely right since the buzzer’s rated voltage is 5 V, it makes more sense to drive it through a transistor for proper switching. Thank you for pointing that out.
Regarding the bypass option, i realized I should actually place a 3 Pin Male Header my bad . Thank you btw.
