Using TT Electronics HM31-20050LF Current Sense Transformer with Arduino Uno.
I am using TT Electronics HM31-20050LF Current Transformer (https://www.mouser.com/datasheet/2/414/ttelectronics_03312016_HM31-1210284.pdf) to detect current through a wire. I have been following primarily these two guides:
  1. CT sensors - Interfacing with an Arduino | Archived Forum
  2. Learn | OpenEnergyMonitor
I selected a burden resistor of 10 Ohms and our Current Transformer has ratio of 50:1. Therefore, in my code other than converting the 0-1023 range to the 0-5v range and taking true RMS all I should have to do is multiply by a factor of 5(÷10 and ×50). For testing purposes my load is a single lamp pulling 0.5A according to this power meter (http://www.p3international.com/manuals/p4400_manual.pdf). However, the Arduino with the help of my code is outputting 0.15A.
My current assumption is that the transformer they are using in the guides (http://www.mcielectronics.cl/website_MCI/static/documents/Datasheet_SCT013.pdf) have some sort of built in functionality that I may need to recreate.
In practice, you need to calibrate your entire setup against a wide range of loads. 0.5 A is minimal, and you need at least 15 A in the primary circuit to properly calibrate the upper end. A 1500 W room heater would be suitable for the maximum load.
Good general tutorial on calibration here.
