Using Two 4051 multiplexer demultiplexer
Hi. I am doing a project to measure array capacitors. I have a working capacitance measuring circuit. I am using two 4051 multiplexer chip, one for charging the capacitor and the other for taking in measurement reading. If I select one pin of the 4051 to charge the capacitor and the other pin of the other 4051 to take in measurement reading, it works i.e. I am able to measure one capacitor. However, when I measure capacitors in array on 8 channels, the measurement becomes wrong value. It seems that the value, let say on channel one, some of it will "leak" into the second channel, giving wrong result. I am not sure what is the reason.
const int pin_Out_S0 = 8;
const int pin_Out_S1 = 9;
const int pin_Out_S2 = 10;
const int pin_Out_S00 = 5;
const int pin_Out_S11= 6;
const int pin_Out_S22 = 7;
const int pin_In_Mux1 = A0;
const int outputPinMux = A2;
const int numReadings = 10;
const int numChannel = 8;
const float strayCap = 27.7*2.8; //initially this was 30.00
const int maxADC = 1023;
float capacitance[numChannel] = {0.0};
int readings[numChannel][numReadings];
int readIndex = 0;
int channelIndex = 0;
int total[numChannel] = {0};
int average[numChannel] = {0};
pinMode(pin_Out_S0, OUTPUT);
pinMode(pin_Out_S1, OUTPUT);
pinMode(pin_Out_S2, OUTPUT);
pinMode(pin_Out_S00, OUTPUT);
pinMode(pin_Out_S11, OUTPUT);
pinMode(pin_Out_S22, OUTPUT);
pinMode(outputPinMux, OUTPUT);
pinMode(pin_In_Mux1, OUTPUT);
for(int thisChannel = 0; thisChannel< numChannel; thisChannel++){
for(int thisReading = 0; thisReading < numReadings; thisReading++){
readings[thisChannel][thisReading] = 0;
do{
total[channelIndex] = total[channelIndex] - readings[channelIndex][readIndex];
pinMode(pin_In_Mux1, INPUT);
digitalWrite(outputPinMux, HIGH);
updateMux(channelIndex);
updateMux1(channelIndex);
readings[channelIndex][readIndex] = analogRead(pin_In_Mux1);
total[channelIndex] = total[channelIndex] + readings[channelIndex][readIndex];
//Clear everything for next measurement
digitalWrite(outputPinMux, LOW);
//Calculate and print result
average[channelIndex] = total[channelIndex] / numReadings;
capacitance[channelIndex] = (float)average[channelIndex] * strayCap / (float)(maxADC - average[channelIndex]);
Serial.print(channelIndex);
Serial.print(": ");
Serial.print(capacitance[channelIndex],2);
Serial.print(F(" pF ("));
Serial.print(average[channelIndex]);
Serial.print(F(") "));
channelIndex = channelIndex + 1;
}while(channelIndex<numChannel);
channelIndex = 0;
readIndex = readIndex + 1;
if(readIndex >= numReadings){
readIndex = 0;
Serial.println("");
void updateMux(int i){
digitalWrite(pin_Out_S00, HIGH && (i & B00000001));
digitalWrite(pin_Out_S11, HIGH && (i & B00000010));
digitalWrite(pin_Out_S22, HIGH && (i & B00000100));
void updateMux1 (int i) {
digitalWrite(pin_Out_S0, HIGH && (i & B00000001));
digitalWrite(pin_Out_S1, HIGH && (i & B00000010));
digitalWrite(pin_Out_S2, HIGH && (i & B00000100));
I am confused. What is all the math with the subtracting from total? Huh? What is the purpose of the total array? It seems you are making it needlessly complex if all you are trying to do is read 8 capacitor values.
