Hi, I'm new to the Arduino world an I'm trying to excecute two different loops when a button is pushed.
More precisely what I'm trying to do is that when a button is pushed, a for loop will happen until the other button is pushed or the for condition is met, wichever happens first. As soon as the other button is pushed, the first button's loop will end and that will be the end of the program. The code I have so far is this>
#include <LiquidCrystal.h>
const int pinOn = 10;
const int pinOff = 9;
const int pinledOn = 13;
const int pinledOff = 8;
LiquidCrystal lcd(12,11,5,4,3,2);
int estaon = 0;
int estaoff = 0;
int inicioOn = 0;
int inicioOff = 0;
int switchVar = 0;
Serial.begin (9600);
pinMode(pinOn, INPUT);
pinMode(pinOff, INPUT);
pinMode(pinledOn, OUTPUT);
pinMode(pinledOff, OUTPUT);
lcd.begin(16,2);
void Encendido (){
for (int contador = 0; contador < 1000; contador++){
digitalWrite(pinledOn, HIGH); // Enciende el LED
lcd.setCursor(0,0);
lcd.print(" Filling ");
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
delay(10000);
digitalWrite(pinledOn, LOW);
lcd.setCursor(0,0);
lcd.print(" Bottle Ready");
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Cantidad: "+String(contador+1));
lcd.setCursor(0,1);
delay(10000);
void Apagado() {
digitalWrite(pinledOff, HIGH);
lcd.setCursor(0,0);
lcd.print(" Bye ");
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" OFF ");
lcd.setCursor(0,1);
estaon = digitalRead(pinOn);
estaoff = digitalRead(pinOff);
// WAS THE ON BUTTON PUSHED?
if (estaon == LOW && inicioOn == HIGH) {
switchVar = 1;
// WAS THE OFF BUTTON PUSHED?
else if (estaoff == LOW && inicioOff == HIGH) {
switchVar = 2;
inicioOn = estaon;
inicioOff = estaoff;
switch (switchVar)
case 1:
Encendido ();
case 2:
Apagado ();
So far, when I press the On button, the loop works fine; but when I press the Off button the On loops keeps going and its supposed to end and show a Bye message. Any tips?
Just a hint - create a "state machine":
Your buttons pressed just sets a state. In a single loop you check all the possible state combinations and do what you want to do.
Simplified example (symbolic, not usable code):
int state = 0; //have previous and current state bits in it: bit 7..4 = previous, bit 3..0 = current
loop() {
if (Button0Pressed())
state |= 0x1; //set state bit 0
state &= ~0x1; //clear state bit 0
if (Button1Pressed())
state |= 0x2;
state &= ~0x2;
switch (state) {
case 0x00 : //nothing pressed, and nothing before
case 0x01 : //Button0 is pressed now, not Button1
case 0x02 : //Button1 is pressed now, not Button0
case 0x10 : //Button0 was active before, now released
case 0x20 : //Button1 was active before, now released
case 0x11 : Button0 is still pressed - but not Button0 (now and before)
case 0x22 : Button1 is still pressed - but not Button0
case 0x10 : Button0 is released now after it was pressed
case 0x20 : Button1 is released now after it was pressed
case 0x03 :
... //add all the other combinations, e.g. both buttons pressed, released ...
case 0x30 :
... //just to make it complete
//or use "fallthrough" on some combinations, to reuse existing code
case ... :
//update previous state:
state &= ~0xF0;
state |= (state << 4); //we use bit 7..4 as previous, bit 0..3 is current
delay(1000); //just to illustrate that previous and current state should not be
//identical so quickly, we wait for 1 second "press interval"
Think in states and program a state machine..., here actually just decoding all combinatoric states possible.
Try this and then convert it into "Blink without delay" approach:
pinMode(13, OUTPUT);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
if (digitalRead(8) == LOW)
for (int i = 0; i < 5; i++)
digitalWrite(13, HIGH);
delay(200);
if (digitalRead(9) == LOW)
digitalWrite(13, LOW);
delay(200);
Serial.println("Bye");
while (1);
1. Upload the above sketch. Connect a jumper at DPin-8 (pinOn). Gently, touch the other end of the jumper with GND-pin. Check that L (built-in LED connected at DPin-13) blinks for 5 times at 200 ms interval. At the end "Bye" message will appear on the Serial Monitor.
2. Connect a jumper at DPin-9 (pinOff). Press RESET Button of the UNO. Start the blinking of L by touching the open end of DPin-8 jumper. At the end-of-2/3 blinks, gently touch the other end of DPin-9 jumper with GND-pin. Check that L is not blinking and the message "Bye" has appeared on Serial Monitor
So, when you press the left push button, the circuit will let the fluid pass for 10 seconds, then it will stop for 10 seconds while the operator changes the bottle and then starts again until the right button is pressed. So far I've managed to make the first button work, but it doesn't read the Off input. I think its beacuse of the Delay that consumes all the proccesor.
launches a process of 10 second filling and 10 second bottle changing periods numbering… 1000.
Without a glance at any buttons. That's 5.5 hours, lotsa bottles and prolly not what you meant.
You have to change it up entirely or at least look at the button within that loop to see if breaking out of the loop is called for (button presst, I guess).
Yeah, originally I wasn't using the for loop. At the end, the contador variable is just to show on screen how many bottles have been filled up, but that can be achieved without the for. But still without the for it's still not reading the Off input.
Post in a new response the full code as you are talking about. Not gonna guess and try to keep my version consistent with yours.
You do know that it still means (if I at all understand you) that the button will be ignored for the 20 seconds a loop-less bottle fill and exchange process is coded to take… you may want to start thinking about coding this in a better manner as has been variously suggested above.
@Perehama my Spanish isn't what it ever was, but the code speaks clearly.
It is two buttons and history for two buttons in order to recognize two buttons that change state between just two values.
So the program does nothing (state is 0) until a button is pressed, then will forever more be in state 1 or state 2 depending on the last button presst.
I had to hack it a bit to save time wiring it up. You play with it here:
I used simpler functions to demonstrate the flow. If you have 5.5 hours, you can test it with the real functions which are in there still, just edit appropriately.
@alto777 I only reply in Spanish to keep mine up. I was posing the question to @luismp as to the states, because it wasn't clear to me from the OP code or initial description. The code shared overly complicates things (this is a really simple program) and has a lot of global flags with similar semantics. This suggests to me that the OP hasn't thought through the states of the machine.
