using two buttons to control 1 motor
I am looking to have a stepper motor spin at a constant rate unless I press (and hold down) 1 of 2 buttons. One to make it go slower and one to make it go faster.
I have confirmed that both buttons do work by writing a sketch that only looks for one button.
I am just not sure how the if/else lines are logically read. This seems right but only the RA_buttonFast button works.
#include <AccelStepper.h>
int RAmotorSpeed = 1000; // steps per second
int DecMotorSpeed = 500;
int half_RAspeed = 500;
int double_RAspeed = 2000;
int MaxSpeed = 10000;
int RADirPin = 12; //digital pin 12
int RAStepPin = 11; //digital pin 11
int EN_PIN_RA = 10; //enable (CFG6)
int EN_PIN_dec = 7; //enable dec cfg6
int DecDir = 9; //dec direction pin
int DecStep = 8; //dec step pin
const int RA_buttonSlow = 14; // the number of the pushbutton pin
const int RA_buttonFast = 15;
int RA_Slow_buttonState = 0; // variable for reading the pushbutton status
int RA_fast_buttonState = 0;
//set up the accelStepper intance
//the “1” tells it we are using a driver
AccelStepper stepperRA(1, RAStepPin, RADirPin);
AccelStepper stepperDec(1, DecStep, DecDir);
stepperRA.setMaxSpeed(MaxSpeed);
stepperRA.setSpeed(RAmotorSpeed);
stepperDec.setMaxSpeed(MaxSpeed);
stepperDec.setSpeed(DecMotorSpeed);
pinMode(RA_buttonSlow, INPUT);
pinMode(RA_buttonFast, INPUT);
stepperRA.runSpeed();
stepperDec.runSpeed();
// read the state of the pushbutton value:
RA_Slow_buttonState = digitalRead(RA_buttonSlow);
RA_fast_buttonState = digitalRead(RA_buttonFast);
// check if the pushbutton is pressed. If it is, the buttonState is LOW
if (RA_Slow_buttonState == LOW) { // make motor turn half as fast
stepperRA.setSpeed(half_RAspeed);
else if (RA_Slow_buttonState == HIGH) { // return to normal speed
if (RA_fast_buttonState == LOW){ // make motor turn 2x fast
stepperRA.setSpeed(double_RAspeed);
else if (RA_fast_buttonState == HIGH){ // return to normal speed
solved:
else if (RA_fast_buttonState == LOW){ // make motor turn 2x fast
else { // return to normal speed
So, every time through loop() that sees that the appropriate switch is pressed, double or halve the speed of the motor. Good thing volume controls don't work that way.
