Hello everyone,
I am trying to turn a speaker on and off with two buttons, the first one plays the sound, and the second one stops it. Currently, the first button will trigger the sound, but the second button does not stop the sound from playing. Any help would be appreciated:)
const int button1Pin = 2; // pushbutton 1 pin
const int button2Pin = 3; // pushbutton 2 pin
const int ledPin = 13; // LED pin
const int buzzerPin = 9;
const int songLength = 5;
char notes[] = "cdefg"; // a space represents a rest
int beats[] = {1, 1, 1, 1, 1};
// The tempo is how fast to play the song.
// To make the song play faster, decrease this value.
int tempo = 113;
#include <Wire.h>
char array1[] = "Alarm Activated "; //the string to print on the LCD
char array2[] = "Alarm Deactivated "; //the string to print on the LCD
int tim = 250; //the value of delay time
// initialize the library with the numbers of the interface pins
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
pinMode(button1Pin, INPUT);
pinMode(button2Pin, INPUT);
pinMode(ledPin, OUTPUT);
pinMode(buzzerPin, OUTPUT);
lcd.init(); //initialize the lcd
lcd.backlight(); //open the backlight
int button1State, button2State; // variables to hold the pushbutton states
int i, duration;
button1State = digitalRead(button1Pin);
button2State = digitalRead(button2Pin);
if (button1State == LOW)
digitalWrite(ledPin, HIGH); // turn the LED on
lcd.setCursor(15, 0); // set the cursor to column 15, line 0
for (int positionCounter1 = 0; positionCounter1 < 26; positionCounter1++)
lcd.scrollDisplayLeft(); //Scrolls the contents of the display one space to the left.
lcd.print(array1[positionCounter1]); // Print a message to the LCD. //displays "Alarm Activated" on lcd
delay(tim); //wait for 250 microseconds
lcd.clear(); //Clears the LCD screen and positions the cursor in the upper-left corner.
while (button2State == HIGH)
for (i = 0; i < songLength; i++) // step through the song arrays
duration = beats[i] * tempo; // length of note/rest in ms //loops buzzer sound forever
if (notes[i] == ' ') // is this a rest?
delay(duration); // then pause for a moment
else // otherwise, play the note
tone(buzzerPin, frequency(notes[i]), duration);
delay(duration); // wait for tone to finish
delay(tempo / 10); // brief pause between notes
noTone(buzzerPin); //turns the buzzer off
delay(duration);
digitalWrite(ledPin, LOW); // turn the LED off
lcd.setCursor(15, 1); // set the cursor to column 15, line 1
for (int positionCounter = 0; positionCounter < 26; positionCounter++)
lcd.scrollDisplayLeft(); //Scrolls the contents of the display one space to the left. //displays "Alarm Deactivated" on lcd
lcd.print(array2[positionCounter]); // Print a message to the LCD.
int frequency(char note)
// This function takes a note character (a-g), and returns the
// corresponding frequency in Hz for the tone() function.
int i;
const int numNotes = 8; // number of notes we're storing
// The following arrays hold the note characters and their
// corresponding frequencies. The last "C" note is uppercase
// to separate it from the first lowercase "c". If you want to
// add more notes, you'll need to use unique characters.
// For the "char" (character) type, we put single characters
// in single quotes.
char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' };
int frequencies[] = {262, 294, 330, 349, 392, 440, 494, 523};
// Now we'll search through the letters in the array, and if
// we find it, we'll return the frequency for that note.
for (i = 0; i < numNotes; i++) // Step through the notes
if (names[i] == note) // Is this the one?
return (frequencies[i]); // Yes! Return the frequency
return (0); // We looked through everything and didn't find it,
// but we still need to return a value, so return 0.
