Using two DHT 22's with UNO
Hi all.
I am trying to write a sketch for UNO that uses tw DHT 22’s, one that measures Temperature & Humidity in an Air Conditioned Display Cabinet, and the other to measure Temperature & Humidity in the room the Cabinet is in.
I want the Cabinet DHT22 to send a relay HIGH to turn a Fan on, when the Temperature exceeds the set point.
With my sketch the fan relay does not go HIGH, i have tried several different approaches, even copying similar Sketches, but nothing as worked so far, this is why i need your help, what am i doing wrong?
Ray
// Libraries
// Libraries
#include <LCD.h>
#include <LiquidCrystal.h>
#include <Wire.h>
#include <DHT.h>
//Constants
#define DHT1PIN 10    // Cabinet Sensor - what pin we're connected to
#define DHT2PIN 11   // Room Sensor -what pin we're conneted to
#define DHT1TYPE DHT22   // DHT 22  (AM2302)
#define DHT2TYPE DHT22   // DHT 22  (AM2302)
#define fan 12   // what pin fan is connected to.
#define I2C_ADDR 0x27  //ALWAYS USE THIS WITH LCD I2C and Addres 0x27
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
int maxHum = 55; // RH%
int maxTemp = 21; //degrees "C"
DHT dht1(DHT1PIN, DHT1TYPE);
DHT dht2(DHT2PIN, DHT2TYPE);
pinMode(fan,OUTPUT);
Serial.println("DHTxx test!");
lcd.begin(20,4);
dht1.begin();
dht2.begin();
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
delay(2000);   // Wait a few seconds between measurements.
float h1 = dht1.readHumidity();
float t1 = dht1.readTemperature();
float h2 = dht2.readHumidity();
float t2 = dht2.readTemperature();
if (isnan(t1) || isnan(h1))
Serial.println("Failed to read from DHTs");     // check if returns are valid, if they are NaN (not a number) then something went wrong!
if(h1 > maxHum || t1 > maxTemp)
digitalWrite(fan, HIGH);
digitalWrite(fan, LOW);
Serial.print("Cabinet Humidity : ");
Serial.print(h1);
Serial.print(" %\t");
Serial.print("Cabinet Temperature : ");
Serial.print(t1);
Serial.println(" Degrees C");
Serial.print("Room Humidity : ");
Serial.print(h2);
Serial.print("Room Temperature : ");
Serial.print(t2);
// Print to LCD data from DHT1
lcd.clear();
lcd.setCursor(1,0);
lcd.print("Cab Temp : ");
lcd.print(t1);
lcd.print(" ");
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(2,1);}
lcd.print("Cab Hum : ");
lcd.print(h1);
lcd.print(" % ");
// Print to LCD data from DHT2
lcd.setCursor(0,2);
lcd.print("Room Temp : ");
lcd.print(t2);
lcd.print(" ");
lcd.print("C");
lcd.setCursor(1,3);
lcd.print("Room Hum : ");
lcd.print(h2);
lcd.print(" % ");
delay(4000); // Wait 4 seconds
What do the debug prints say?
#define DHT2PIN 4    // Room Sensor -what pin we're conneted to
#define D4_pin 4
Are you using pin 4 for 2 different purposes ?
To Globalmoderator. I have corrected this error, Pin 4 is now Pin8
To AWOL. being self taught, i have never done debugging, can you give me an example?
Which one ?
Use Serial.print() at strategic points in the program to print values such as h1, t1, h2 and t2. Do they look right ? Put Serial.prints inside the conditional code blocks so that you know that the code block is being executed
gresleyman:
To Full Member - you read what your sketch has printed to the serial monitor, and see if that aligns with your expectations.
I am still unsure of what to do, i have used Serial.println() to display Temperature & Humidity from each sensor, both Temperatures read the same, Humidity is within one degree of each other, so perfect for me so far.
To monitor action of relay (HIGH / LOW) i am not sure what to write or to where i should write it. My relay is on a board, i have a Red led for Power ON and a Green LED when the relay gets a signal from the UNO, i am not getting the Green led when i alter the Set points in the sketch to actuate the relay.
    if (h1 > maxHum || t1 > maxTemp)
Print these 4 values immediately before you test them. I suggest that you print text labels too so that you can see which values is which
Why is the code following the "failed" message in curly brackets ?
Hi.
Sorry i think translation is awkward.
The curly brackets A ROUND FAILED " " are quotation / punctuation marks, done to highlight the statement.
Print 4 values ?? before testing ?? I need help here. You are showing only 2 values, h1 & t1. where do i print them to ?? The values are displayed in the Serial Monitor, when Arduino has analysed the data it receives from the DHT 22's, how do i print off what has not yet happened ??
No curly brackets like this { }.
You’ve got a superfluous opening one, but I can’t see the closing one
  Serial.print("h1 : ");
  Serial.println(h1);
  Serial.print("maxHum : ");
  Serial.println(maxHum);
  Serial.print("t1 : ");
  Serial.println(t1);
  Serial.print("maxTemp : ");
  Serial.println(maxTemp);
Hi UKHELIBOB
i have tried your sketch and i get the same results, i.e data from the DHT's, but the relay for the Fan on Pin12 is still not energising when the actual Temp & hum is above the set points in the sketch.
Hi AWOL.
Where are you looking i see two {} these are called Parenthesis
No, those are braces.
These () are parentheses.
I’m looking at the superfluous opening brace right after "Serial.println(“Failed…”
Hi AWOL.
When i remove the brackets from the sketch, it will not download, i get an error message -
"." before string content
These are brackets .
Where did you remove them from?
Hi all.
Something strange, or it is at least to me, after taking advice and making recommended changes, and still not finding a solution to my problem, i again downloaded my original sketch, and the situation i have no is this -
int naxHum is set to 55% , int maxTemp is set to 21 degrees C. the relay for the fan is now HIGH, but the actual figures are Humidity 45%, Temperature 19 Degrees ??
I do not know whats going on ?
Hint: we can’t see your code.
We can’t see your schematic.
gresleyman:
Hi UKHELIBOB
i have tried your sketch and i get the same results, i.e data from the DHT’s, but the relay for the Fan on Pin12 is still not energising when the actual Temp & hum is above the set points in the sketch.
Print a message when you write to pin 12 to turn the fan on
Do you see the message even though the fan does not run ?
Hi ukhelibob
Is this what you mean ??
digitalWrite(fan, HIGH); //Fan is RUNNING}
digitalWrite(fan, LOW); Fan is OFF
Has i have stated previously, the situation with my project now is this -
Both DHT’s taking data and displaying it on a 20,4 lcd, sketch is written so the UNO sets pin 12 HIGH to energise a relay which switches ON a 12 vdc Fan. when the temperature reaches 25 Deg C or 60% Humidity. My situation now is this. Temp is 19 Deg C Humidity is 48%, and the Relay is energised, despite both set points being well below setting point ?? i do not understand.
I have uploaded my code again, if it helps, cannot give a schematic yet, as i have used “Powerpoint” not a proper CAD program.
// Libraries
#include <LCD.h>
#include <Wire.h>
#include <DHT.h>
//Constants
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
int maxHum = 60; // RH%
int maxTemp = 25; //degrees "C"
lcd.begin(20,4);
dht1.begin();
dht2.begin();
digitalWrite(fan, HIGH);  //Fan Turns running
Serial.print(h1);
Serial.print(t1);
Serial.print(h2);
Serial.print(t2);
lcd.clear();
lcd.setCursor(1,0);
lcd.print(t1);
lcd.print(" ");
lcd.print("C");
lcd.print(h1);
lcd.print(" % ");
lcd.setCursor(0,2);
lcd.print(t2);
lcd.print(" ");
lcd.print("C");
lcd.setCursor(1,3);
lcd.print(h2);
lcd.print(" % ");
