Here is a snippet of the problem area. What I am trying to do, is control a series of relays with the serial terminal. I have that part working correctly, but I want to add the ability to have each relay turn on and off at different rates, individually, controlled also from the serial terminal.
Currently, I am able to change the onTime and offTime from the terminal, but only if it's a global variable, so every relay follows the same onTime and offTime. I also am able to get it to work buy using a different global variable for each relay, but that adds way too many unnecessary lines of code while also limiting the flexibility. Currently I'm running 8 relays connected to various things.
I am open to suggestions of a better way to do this, but here is what I am trying to do now. Keep in mind, this is only a small test version I'm using in order to try and figure out how to change the onTime, offTime, ledPin, and analog input from within the loop.
class Test
int ledPin;
int photoPin;
long onTime;
long offTime;
int ledState = 0;
int lightReading;
unsigned long lightStart;
unsigned long lightStop;
unsigned long nextChangeTime = 0;
public:
Test(int led, int photo, int on, int off)
ledPin = led;
pinMode(ledPin, OUTPUT);
photoPin = photo;
pinMode(photoPin, INPUT);
ledState = LOW;
onTime = on;
offTime = off;
unsigned long currentTime;
void Lightme()
unsigned long currentTime = millis();
if (currentTime >= nextChangeTime) {
nextChangeTime=(millis()+onTime);
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
digitalWrite(ledPin, ledState);
void Update(int led, int photo, int on, int off)
OnTime = on;
OffTime = off;
pinMode(7, OUTPUT);
Test sample1 = Test(7,A0,100,250);
sample1.Update(7,A0,1000,1000);
sample1.Lightme();
Warning: Your constructor calls pinMode() (twice) but the Arduino runtime library is not initialized until AFTER the global objects are initialized. Move the Arduino calls to a 'begin' method and call it from setup().
class Test
int ledPin;
int photoPin;
unsigned long onTime;
unsigned long offTime;
int ledState;
int lightReading;
unsigned long lastChangeTime;
public:
Test(int led, int photo, unsigned long on, unsigned long off)
ledPin = led;
photoPin = photo;
ledState = LOW;
onTime = on;
offTime = off;
lastChangeTime = 0;
void begin()
void Lightme()
if (currentTime - lastChangeTime >= onTime)
lastChangeTime = currentTime;
ledState = (ledState == LOW) ? HIGH : LOW;
void Update(unsigned long on, unsigned long off)
onTime = on;
offTime = off;
Test sample1 = Test(7, A0, 100, 250);
pinMode(7, OUTPUT);
sample1.begin();
sample1.Update(1000, 1000);
sample1.Lightme();
Very helpful Johnwasser, Thank you! I have been sort of crash coursing myself through learning to program for about the last year on and off, and I often get ahead of myself, and therefore lost.
johnwasser:
I'm interested in what's going on here if you have time to explain. I did a quick search but I'm curious about the fundamentals behind it, so I can use it in other parts of my larger program.
Thanks!
rpc1986:
Thanks!
