Using two i2c / one spi / three serial to get sensors data, and stop running
Using Aduino due, using two i2c, one SPI, and three serial communications
Each has received the values of internal ADC / external ADC / RTC / SD Card / LoRa / GPS module.
The individual experiments have been successfully completed, and work is being integrated as follows.
But if you attach more than 3 modules above and communicate, the work will be stopped.
I don't know why the work of Arduino Due stops at all.
The code is as follows.
#include <DueTimer.h>
#include <Wire.h>
#include <ADS1115.h>
#include <SPI.h>
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
const int chipSelect = 36;
String dataName;
File dataFile;
/* I/O INIT */
#define SENSOR_00   A0
#define SENSOR_01   A1
#define SENSOR_02   A2
#define SENSOR_03   A3
/* RTC */
#define DS3231_I2C_ADDRESS 104
byte seconds, minutes, hours;
char weekDay[4];
byte tMSB, tLSB;
float temp3231;
/* ADC */
unsigned int  ADC_Value00 = 0;
unsigned int  ADC_Value01 = 0;
unsigned int  ADC_Value02 = 0;
unsigned int  ADC_Value03 = 0;
ADS1115 ads1;
ADS1115 ads2;
int16_t adc0, adc1, adc2, adc3,adc4, adc5, adc6, adc7;
String ADS1115_str = "";
/* GPS */
String FINAL_GPS_VALUE ="";
bool GPS_VALUE_EMPTY = true;
const byte numChars = 40;
char receivedChars[numChars];
boolean newData = false;
/* LoRa */
bool LoRaParameter_info = true;
String receivedCharsLoRa;
boolean newDataLoRa = false;
int count_NO = 0;
  /* Serial */
  Serial.begin(115200);   // Monitoring
  Serial1.begin(9600);    // GPS
  Serial2.begin(9600);    // LoRa
  /* Timer */
  Timer3.attachInterrupt(ADC_CAL_START).start(1000000);
  Timer4.attachInterrupt(SENSOR_DISPLAY).start(2000000);
  /* ADC */
  analogReadResolution(12);
  pinMode(SENSOR_00, INPUT);
  pinMode(SENSOR_01, INPUT);
  pinMode(SENSOR_02, INPUT);
  pinMode(SENSOR_03, INPUT);
  /* ADS1115 */
  ads1.getAddr_ADS1115(ADS1115_DEFAULT_ADDRESS);
  ads2.getAddr_ADS1115(ADS1115_VDD_ADDRESS);
  ads1.setGain(GAIN_TWOTHIRDS);
  ads2.setGain(GAIN_TWOTHIRDS);
  ads1.setMode(MODE_CONTIN);
  ads2.setMode(MODE_CONTIN);
  ads1.setRate(RATE_860);
  ads2.setRate(RATE_860);
  ads1.setOSMode(OSMODE_SINGLE);
  ads2.setOSMode(OSMODE_SINGLE);
  ads1.begin();   //ADS1115 - 1 start
  ads2.begin();   //ADS1115 - 2 start
  Wire1.begin();  //RTC 시작
void SDCARD_INIT(){
  pinMode(SS, OUTPUT);
  dataName = "datalog.txt";
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    while (1) ;
  Serial.println("card initialized.");
  dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (! dataFile) {
    Serial.println("error opening datalog.txt");
    while (1) ;
  if(LoRaParameter_info){
    LoRaCommunication();
  watchConsole();
  get3231Date();
  GPS_INFO_DISPLAY();
  ADS1115_DISPLAY();
  SDCARD_DATA_LOG();*/
} // loop
void LoRaCommunication(){
  static boolean recvInProgress = false;
    static byte ndx = 0;
    String startMarker = "$";
    String endMarker = ">";
    String rc;
    Serial2.println("$Rpar=");
    while (Serial2.available() > 0 && newDataLoRa == false) {
        rc = Serial2.readString();
        if (recvInProgress == true) {
            if (rc.indexOf(endMarker) == 0) {
                receivedCharsLoRa = rc;
            else {
                newDataLoRa = true;
        else if (rc.indexOf(startMarker) != 0) {
            recvInProgress = true;
    if ((newDataLoRa == true) ) {
        String BufferTbd3 = "$Tbupc=170:";
        LoRaParameter_info = false;
        Serial.println(receivedCharsLoRa);
        Serial2.println(BufferTbd3 + receivedCharsLoRa);
void ADC_CAL_START(){
    NTCsensor_Collect_10data();
    Voltage5_Collect_10data();
    Voltage3_Collect_10data();
    Door_Collect_10data();
void GPS_INFO_DISPLAY(){
    char startMarker = '
Can anybody help me?;
   char endMarker = '\n';
   char rc;
   while (Serial1.available() > 0 && newData == false) {
       rc = Serial1.read();
           if (rc != endMarker) {
               receivedChars[ndx] = rc;
               ndx++;
               if (ndx >= numChars) {
                   ndx = numChars - 1;
           else {
               receivedChars[ndx] = '\0';
               ndx = 0;
               newData = true;
       else if (rc == startMarker) {
   if ((newData == true) ) {
      if(receivedChars[3] == 'M'){
       FINAL_GPS_VALUE = "";
       for(int i = 0 ; i < 40 ; i++){
         FINAL_GPS_VALUE += receivedChars[i];
      } //delay(100);
     newData = false;
void ADS1115_DISPLAY(){
   byte error1, error2;
   int8_t address1, address2;
   address1 = ads1.ads_i2cAddress;
   address2 = ads2.ads_i2cAddress;
   Wire.beginTransmission(address1);
   Wire.beginTransmission(address2);
   error1 = Wire.endTransmission();
   error2 = Wire.endTransmission();
   if (error1 == 0 )
       adc0 = ads1.Measure_SingleEnded(0);
       adc1 = ads1.Measure_SingleEnded(1);
       adc2 = ads1.Measure_SingleEnded(2);
       adc3 = ads1.Measure_SingleEnded(3);
       adc4 = ads2.Measure_SingleEnded(0);
       adc5 = ads2.Measure_SingleEnded(1);
       adc6 = ads2.Measure_SingleEnded(2);
       adc7 = ads2.Measure_SingleEnded(3);
ADS1115_str = "";
ADS1115_str += "AIN0: ";
       ADS1115_str += adc0;
       ADS1115_str += ", AIN1: ";
       ADS1115_str += adc1;
       ADS1115_str += ", AIN2: ";
       ADS1115_str += adc2;
       ADS1115_str += ", AIN3: ";
       ADS1115_str += adc3;
       ADS1115_str += ", AIN4: ";
       ADS1115_str += adc4;
       ADS1115_str += ", AIN5: ";
       ADS1115_str += adc5;
       ADS1115_str += ", AIN6: ";
       ADS1115_str += adc6;
       ADS1115_str += ", AIN7: ";
       ADS1115_str += adc7;
       Serial.println("ADS1115 Disconnected!");
   //delay(1000);
void SDCARD_DATA_LOG(){
String dataString = "";
 for (int analogPin = 0; analogPin < 3; analogPin++) {
   dataString += analogPin;
dataFile.println(dataString);
 Serial.println(dataString);
 dataFile.flush();
void SENSOR_DISPLAY(){
 String RTC_display = "";
 RTC_display += (int)hours;
 RTC_display += ":";
 RTC_display += (int)minutes;
 RTC_display += ":";
 RTC_display += (int)seconds;
 RTC_display += "\r\n";
 String Sensor_display = "";
 //Sensor_display += RTC_display;
 Sensor_display += "3.3V : ";
 Sensor_display += ADC_Value01;
 Sensor_display += "5V : ";
 Sensor_display += ADC_Value00;
Sensor_display += ",     NTC : ";
 Sensor_display += ADC_Value02;
Sensor_display += ",     Door : ";
 Sensor_display += ADC_Value03;
 Sensor_display += "\r\n";
 Sensor_display += "GPS : ";
 Sensor_display += FINAL_GPS_VALUE;
Sensor_display += "ADS1115 : ";
 Sensor_display += ADS1115_str;
 Serial.println(Sensor_display);
void Voltage5_Collect_10data(){
 ADC_Value00 = analogRead(SENSOR_00);
void Voltage3_Collect_10data(){
 ADC_Value01 = analogRead(SENSOR_01);
void NTCsensor_Collect_10data(){
 ADC_Value02 = analogRead(SENSOR_02);
void Door_Collect_10data(){
 ADC_Value03 = analogRead(SENSOR_03);
/* RTC /
byte decToBcd(byte val)
 return ( (val/10
16) + (val%10) );
void watchConsole()
 if (Serial.available()) {
   if (Serial.read() == 84) {
     get3231Date();
     Serial.println(" ");
void get3231Date()
Wire1.beginTransmission(DS3231_I2C_ADDRESS);
 Wire1.write(0x00); // start at register 0
 Wire1.endTransmission();
 Wire1.requestFrom(DS3231_I2C_ADDRESS, 7);
 if(Wire1.available()) {
   seconds = Wire1.read(); // get seconds
   minutes = Wire1.read(); // get minutes
   hours   = Wire1.read();   // get hours
seconds = (((seconds & B11110000)>>4)*10 + (seconds & B00001111));
   minutes = (((minutes & B11110000)>>4)*10 + (minutes & B00001111));
   hours   = (((hours & B00110000)>>4)*10 + (hours & B00001111));
 else {
switch (day) {
   case 1:
     strcpy(weekDay, "Sun");
when you compile a message shows up at at the bottom of the IDE. this message tells you about RAM usage, among other things. is this very large program consuming all your limited resources?
My sketch tool can not see the RAM usage.
But, I think I have found the cause.
I removed all Serial.print, so all functions work well.
But I do not know why.
Serial2 for communication needs to be used, which is a big problem.
I finally found a reason.
I changed the String to char and used it in Serial.print, so everything was resolved .................
