Hey guys,
first of all: sorry for my bad english. I try my very best ^^
i am a little newbie with the ESP8266 and Arduino. I play around with it since 2 weeks and i already got most things work ![]()
I build some boards for the ESP-01 with two relays. One relay on GPIO 2 and one on GPIO 0.
I connected it via MQTT with ioBroker. I can now switch the relay state with:
0 = Relay_1 off
1 = Relay_1 on
2 = Relay_2 off
3 = Relay_2 on
After this was working i installed the HomeKit Adapter in ioBroker to control the relays via Siri on the iPhone. Unfortunately the HomeKit App will just send a "true" or "false" to the ESP.
So i changed the Sketch a little bit and now i am able to control the first relay:
0 or false = Relay_1 off
1 or true = Relay_1 on
2 = Relay_2 off
3 = Relay_2 on
The problem is, that i can't find a solution for the second relay, because when i add the "true/false" to the second relays, Siri would always turn on/off both relays, as the ESP can't distinguish which relay was meant.
Is there a solution for the ESP to distinguish a simple true/false ?
I ope u guys can maybe help me ![]()
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <Bounce2.h>
#include <EEPROM.h>
#include <ESP8266WebServer.h>
const char* ssid = "...";
const char* password = "...";
const char* mqtt_server = "192.168.178.23";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
const char* clientID = "ESP 2";
//const char* outTopic = "ESPout1";
const char* inTopic1 = "ESPin2.1";
const char* inTopic2 = "ESPin2.2";
#define RelaisPin 2Â // Relais
int active_low = 1;
int relay_pin1 = 2;
int relay_pin2 = 0;
bool relayState1 = LOW;
bool relayState2 = LOW;
ESP8266WebServer server(80);    // Serverport hier einstellen
int val = 0;
// Instantiate a Bounce object :
Bounce debouncer = Bounce();
void setup_wifi() {
 delay(10);
 // We start by connecting to a WiFi network
 Serial.println();
 Serial.print("Connecting to ");
 Serial.println(ssid);
 WiFi.begin(ssid, password);
  for(int i = 0; i<500; i++){
   delay(1);
  Serial.print(".");
 Serial.println("");
 Serial.println("WiFi connected");
 Serial.println("IP address: ");
void callback(char* topic, byte* payload, unsigned int length) {
 String message;
 Serial.print("Message arrived [");
 Serial.print(topic);
 Serial.print("] ");
 for (int i = 0; i < length; i++) {
  Serial.print((char)payload[i]);
  char c = (char)payload[i];
  message += c;
 Serial.println();
 if ((char)payload[0] == '0' || message == "false") {
  digitalWrite(relay_pin1, LOW);
  Serial.println("relay_pin1 -> LOW");
  relayState1 = LOW;
  EEPROM.write(0, relayState1);
  EEPROM.commit();
 } else if ((char)payload[0] == '1' || message == "true") {
  digitalWrite(relay_pin1, HIGH);
  Serial.println("relay_pin1 -> HIGH");
  relayState1 = LOW;
  EEPROM.commit();
 } else if ((char)payload[0] == '2') {
  digitalWrite(relay_pin2, LOW);
  Serial.println("relay_pin2 -> LOW");
  relayState2 = LOW;
  EEPROM.write(1, relayState2);
  EEPROM.commit();
 } else if ((char)payload[0] == '3') {
  digitalWrite(relay_pin2, HIGH);
  Serial.println("relay_pin2 -> HIGH");
  relayState2 = HIGH;
  EEPROM.commit();
void reconnect() {
 // Loop until we're reconnected
 while (!client.connected()) {
  Serial.print("Attempting MQTT connection...");
  // Attempt to connect
  if (client.connect(clientID)) {
   Serial.println("connected");
   client.subscribe(inTopic1);
   client.subscribe(inTopic2);
   Serial.print("failed, rc=");
   Serial.print(client.state());
   Serial.println(" try again in 5 seconds");
   // Wait 5 seconds before retrying
   for(int i = 0; i<5000; i++){
//Â Â Â Â extButton();
    delay(1);
 EEPROM.begin(512);       // Begin eeprom to store on/off state
 pinMode(relay_pin1, OUTPUT);  // Initialize the relay pin as an output
 pinMode(relay_pin2, OUTPUT);  // Initialize the relay pin as an output
 relayState1 = EEPROM.read(0);
 digitalWrite(relay_pin1,relayState1);
 relayState2 = EEPROM.read(1);
 digitalWrite(relay_pin2,relayState2);
Â
 debouncer.interval(50);    // Input must be low for 50 ms
Â
 setup_wifi();         // Connect to wifi
 client.setServer(mqtt_server, 1883);
 client.setCallback(callback);
 if (!client.connected()) {
  reconnect();
 client.loop();
