Using two sensors in I2C with TCA9548A
HELLO !
I’m using myAHRS+ and BMP180 in I2C but have some crash in addresses.
so I bought a I2C multiplexer, TCA9548A but couldn’t understand how it works.
I want to get Eulerian angle and temperature with myAHRS+ and altitude with BMP180
but the OUTPUT data have not updated and print wrong data.
add some code about it. please take a look at the code ! :sweat_smile:
myAHRS__i2c.ino (2.03 KB)
The BMP180 uses 0x77 as I2C address and if the myAHRS+ uses 0x70, then there is no conflict.
What makes you think the address make it crash ?
Can you tell which modules you use ? please give a link to them.
Which Arduino board do you use ?
Do you use a 5V or 3.3V I2C bus ?
Did you run the i2c_scanner ? http://playground.arduino.cc/Main/I2cScanner
Your code is not okay. Did you copy it from somewhere ?
Replace this:
  Wire.beginTransmission(TCAADDR);
  Wire.requestFrom(TCAADDR, 1);
  while(!Wire.available()) {};
  #if ARDUINO >= 100
    value = Wire.read();
  #else
    value = Wire.receive();
  #endif;
  Wire.endTransmission();
  return value;
With this:
  return value;
Perhaps you might have to change the name of a few functions. The readRegister8() is often used in Adafruit library, it might even be in the BMP180 library as well.
