Using two servo motors with Arduino
I got this code from online to help run my robot, and I am having a few issues with making the code work.
I'm having two main problems with my robot. 1) The queue isnt working properly and it runs the first command, waits, and then reruns it like the motor is broken before going back to normal and 2) Whenever I try to run both of the motors at once to make the robot go forwards it the first command gets abrptly canceled
      case VEHICLE_FORWARD :
        if (newCmd) {
          distance = ((long) cmdQueue.getParameter1() * (long) ENCODER_COUNTS_PER_REV / (long) MM_PER_REV);
          speed = speedFwd;
          mtrLeft.startMove(distance,speed);
          mtrRight.startMove(distance,speed);
          setMotorOutputs();
        if (mtrLeft.isStopped() && mtrRight.isStopped()) {
          setMotorOutputs();
          cmdQueue.next();
// This function must be called to start a motion
      void startMove(int pos, int spd) {
        delay(5000);
        Serial.println("startmove");
        if (spd > 0) {
          outputFwd = 1;
          outputRev = 0;
          outputFwd = 0;
          outputRev = 1;
        speedTarget = abs(spd);
        position = abs(pos);
        if (debugPrint) { Serial.print(F("Motion - speed       = ")); Serial.println(speedTarget); }
        if (debugPrint) { Serial.print(F("Motion - position    = ")); Serial.println(position); }
        float tAccel = (float) speedTarget / (float) accelRate;
        float tDecel = (float) speedTarget / (float) decelRate;
        float distAccel = (float) speedTarget / 2.0 * tAccel;
        float distDecel = (float) speedTarget / 2.0 * tDecel;
        float distAtSpeed = (float) position - distAccel - distDecel;
        if (distAtSpeed < 0.0) {  // current written as accel and decel same
          // Serial.println("Motion - Short move logic");
          distAccel = (float) position / 2.0;
          distDecel = (float) position / 2.0;
          distAtSpeed = 0.0;
          tAccel = sqrt(distAccel * 2.0 / (float) accelRate);
          tDecel = sqrt(distDecel * 2.0 / (float) decelRate);
        float tAtSpeed = distAtSpeed / (float) speedTarget;
          // times are in microseconds
        timeAccel = 0;
        timeAtSpeed = tAccel * 1000000;
        timeDecel = timeAtSpeed + tAtSpeed * 1000000;
        pwmLoopI = 0;
        pwmLoopP = 0;
        countEncoder = 0;
        countEncoderLast = 0;
        posProfile = 0;
        speedAtDecel = -10000;
        timeRunning = 0;
        timeRunningLast = 0;
        timerUpdate = 0;
        flagStopped = 0;
        counterStopped = 0;
        running = 1;
Thats is the code for the forward and you can see have mtrLeft and then mtrRight. When mtrRight is called the left motor stops.
Here is my code for the queue
  class Command
    private:
      int start;
      int end;
      int last_cmd;
      int list[MAX_COMMANDS];
      int p1[MAX_COMMANDS];
      int flagFirstScan;
    public:
      inline int   current()  { return list[start]; };
      inline int   getParameter1() { return p1[start]; };
      inline int   empty()    { if (start==end) return 127; else return 0; };
      inline int   last()     { return last_cmd; };
      inline int   firstScan() { int flag = flagFirstScan; flagFirstScan = 0; return flag; }
      Command() {
        clear();
      void clear() {
        start = 0;
        end = 0;
        last_cmd = 0;
        flagFirstScan = 0;
        int n = 0;
        for (n=0;n<MAX_COMMANDS;n++) { list[n] = 0;  p1[n] = 0; }
      void add(int cmd) {
        add(cmd,0);
      void add(int cmd,int par1) {
        list[end] = cmd;
        p1[end] = par1;
        end++;
        if (end >= MAX_COMMANDS) end = 0;
      int next() {
        flagFirstScan = 127;
        if (empty()) return 0;
        last_cmd = list[start];   // save last command
        start++;
        if (start >= MAX_COMMANDS) start = 0;
        return list[start];
  Command cmdQueue;
void loadCommandQueue() {
    cmdQueue.clear();
    cmdQueue.add(VEHICLE_START_WAIT);     // do not change this line - waits for start pushbutton
    cmdQueue.add(VEHICLE_START);          // do not change this line
    // Define robot movement speeds
    // Speed is encoder pulses per second.
    // There is a maximum speed.  Testing will be required to learn this speed.
    //    SETTING THE SPEEDS ABOVE THE MOTOR'S MAXIMUM SPEED WILL CAUSE STRANGE RESULTS
        cmdQueue.add(VEHICLE_SET_MOVE_SPEED,500);     // Speed used for forward movements
        cmdQueue.add(VEHICLE_SET_TURN_SPEED,300);     // Speed used for left or right turns
        cmdQueue.add(VEHICLE_SET_ACCEL,400);         // smaller is softer   larger is quicker and less accurate moves
          // Example list of robot movements
          // This block is modified for each tournament
        cmdQueue.add(VEHICLE_FORWARD,500);
        cmdQueue.add(VEHICLE_TURN_LEFT);
        cmdQueue.add(VEHICLE_TURN_RIGHT);
        cmdQueue.add(VEHICLE_FINISHED);
Thats the queue code and adding to the queue. It is all added to the queue array storage properly, but it still dosen't work and I'm super lost.
If it helps here is the full code
  #include <Arduino.h>
  #include <Wire.h>
  #include <LiquidCrystal_I2C.h>    // this library is needed for the 20x4 display
  #define VERSION           "D4 2.1"
  #define DISPLAY_PRESENT        1  // set to 1 if the 20x4 I2C Display is present
  //  Board: Ardunio Uno
  //  DEFINE ALL I/O PIN CONNECTIONS
  //    *** DO NOT CHANGE ***
  #define PIN_MTR1_ENCA          2
  #define PIN_MTR2_ENCA          3
  #define PIN_PB_START           4
  #define PIN_MTR1_DIR_FWD       5
  #define PIN_MTR1_DIR_REV       6
  #define PIN_MTR2_DIR_FWD       7
  #define PIN_MTR2_DIR_REV       8
  #define PIN_MTR1_PWM           9
  #define PIN_MTR2_PWM          10
  #define PIN_SONIC_PULSE       11
  #define PIN_SONIC_TRIGGER     12
  #define PIN_LED               13
  //************************* ADJUST THE FOLLOWING TO MATCH YOUR ROBOT ****************************
  #define ENCODER_COUNTS_PER_REV  540   // Set to the number of encoder pulses per wheel revolution
  #define MM_PER_REV              220   // Set to the number of mm per wheel revolution (Hence : Diameter * Pi)
  #define ENCODER_COUNTS_90_DEG   200   // Set to the number of encoder pulses to make a 90 degree turn
  #define SPEED_MIN               120    // Minimum speed (pulses/second) use at the end of individual moves
  LiquidCrystal_I2C display(0x27,20,4);  // set the LCD address to 0x27 for a 20 chars and 4 line display
  unsigned long usLast;
  long usecElapsed;
  long usScanLong;
  int  usLongResetCount;
  long usScanAvg;
  long timerusScan;
  int scanCount;
  long timerRunTime;
  int speedFwd;
  int speedTurn;
  int flagTimeRun;
  int flagLastMoveFwd;
  int flagLED;
  float sonicDistance;
  int printStep;
  int printLastCmd;
  unsigned long msTimerPrint;
  unsigned long msTimerMPU;
  unsigned long timerSonicRange;
  unsigned long timerPBStartOn;
  unsigned long timerPBStartOff;
  unsigned long timerDelay;
  #define MAX_COMMANDS    60        // Maximum number of motion commands allowed
  // Command object is used to hold a list of commands to be executed
  class Command
    private:
      int start;
      int end;
      int last_cmd;
      int flagFirstScan;
    public:
      Command() {
        clear();
      void clear() {
        start = 0;
        end = 0;
        last_cmd = 0;
        flagFirstScan = 0;
        int n = 0;
      void add(int cmd) {
        add(cmd,0);
        list[end] = cmd;
        p1[end] = par1;
        end++;
      int next() {
        start++;
        return list[start];
  Command cmdQueue;
  //  List of possible vehicle motion commands
  //   -- Additional motion commands can be added which will require code to execute
  #define VEHICLE_START_WAIT      1       // Wait for the start button to be pressed
  #define VEHICLE_START           2       // First motion command after button press
  #define VEHICLE_FORWARD         10
  #define VEHICLE_TURN_RIGHT      40
  #define VEHICLE_TURN_LEFT       50
  #define VEHICLE_SET_MOVE_SPEED  101
  #define VEHICLE_SET_TURN_SPEED  102
  #define VEHICLE_SET_ACCEL       105
  #define VEHICLE_FINISHED        900     // Must be at the end of the command list
  #define VEHICLE_STOP            1000
  #define VEHICLE_ABORT           2000    // Used to abort the current movement list and stop the robot
  // Loads the command queue with the robots commands to be executed during a run
    cmdQueue.clear();
        // cmdQueue.add(VEHICLE_FORWARD,830);
        // cmdQueue.add(VEHICLE_TURN_LEFT);
        // cmdQueue.add(VEHICLE_FORWARD,500);
        // cmdQueue.add(VEHICLE_TURN_RIGHT);
        // cmdQueue.add(VEHICLE_FORWARD,1000);
        // cmdQueue.add(VEHICLE_FORWARD,1500);
        // cmdQueue.add(VEHICLE_FORWARD,420);
            // This MUST be the last command.
  // Motion object (like a library) that calculates the acceleration used for motor speed
  // control.
  // Distance is encoder pulses
  // Accel is encoder pulses per second^2
  class MotionLogic
    private:
      long timeAccel;
      long timeAtSpeed;
      long timeDecel;
      long timeRunning;
      long timeRunningLast;
      long timerUpdate;
      int pinPWM;
      int outputPWM;
      int outputFwd;
      int outputRev;
      int running;
      int flagStopped;
      int counterStopped;
      int pwmLoopI;
      int pwmLoopP;
      int debugPrint;
    public:
      long accelRate;
      long decelRate;
      long position;
      long posProfile;
      int speedTarget;
      int speedProfile;
      int speedActual;
      int speedMinimum;
      int speedAtDecel;
      long countEncoder;
      long countEncoderLast;
      inline int getOutputPWM() { return outputPWM; };
      inline int getOutputFwd() { return outputFwd; };
      inline int getOutputRev() { return outputRev; };
      inline void incrEncoder() { countEncoder++; };
      inline void debugOn() { debugPrint = 1; };   // used this function to turn on debug print statements
                                                  // recommended to only turn on debug for left or right motor.  NOT both.
      inline int debugState() { return debugPrint; };
      MotionLogic() {
        outputPWM = 0;
        outputFwd = 0;
        outputRev = 0;
        countEncoder = 0;
        debugPrint = 0;
        accelRate = 200;
        decelRate = 200;
        posProfile = 0;
        speedActual = 0;
        speedTarget = 0;
        timeRunning = 0;
        flagStopped = 0;
        counterStopped = 0;
        running = 0;
      int isStopped() {
        if (flagStopped) return 1;
        return 0;
      void setParams(long accel,int spdMin,int pPWM) {
        accelRate = accel;
        decelRate = accel;
        speedMinimum = spdMin;
        pinPWM = pPWM;
      // This object uses the same value for accelerate and decelerate rate
      void setAccel(long accel) {
        accelRate = accel;
        decelRate = accel;
        delay(5000);
        if (spd > 0) {
          outputFwd = 1;
          outputRev = 0;
          outputFwd = 0;
          outputRev = 1;
          distAtSpeed = 0.0;
        timeAccel = 0;
        pwmLoopI = 0;
        pwmLoopP = 0;
        countEncoder = 0;
        posProfile = 0;
        timeRunning = 0;
        timerUpdate = 0;
        flagStopped = 0;
        counterStopped = 0;
        running = 1;
      void stop() {
        outputPWM = 0;
        outputFwd = 0;
        outputRev = 0;
        analogWrite(pinPWM,outputPWM);
        running = 0;
        posProfile = 0;
        speedProfile = 0;
        speedTarget = 0;
      void updateMotion(long usecElapsed) {
        int flagUpdate = 0;
        timerUpdate += usecElapsed;
        if (timerUpdate >= 30000) {
          long delta = countEncoder - countEncoderLast;
          speedActual = delta * 1000000L / timerUpdate;
          countEncoderLast = countEncoder;
          timerUpdate = 0;
          flagUpdate = 1;
          if (running == 0 && speedActual < 4) {
            if (!flagStopped) counterStopped++;
            if (counterStopped > 2) flagStopped = 1;
        if (running == 0) {
          outputPWM = 0;
          outputFwd = 0;
          outputRev = 0;
          pwmLoopP = 0;
          pwmLoopI = 0;
          return;
        if (countEncoder >= (position - 2)) {
          if (debugPrint) {
            Serial.print("STOPPED,");
            Serial.print("timeRunning:");
            Serial.print(timeRunning);
            Serial.print(",encoder:");
            Serial.print(countEncoder);
            Serial.print(",speedActual:");
            Serial.print(speedActual);
            Serial.print(",pwm:");
            Serial.println(outputPWM);
          stop();
          return;
        timeRunning += usecElapsed;
        if (flagUpdate == 0) return;
        float speed;
        if (timeRunning < timeAtSpeed) {
          speed = (float) timeRunning / 1000000.0 * (float) accelRate;
          speedProfile = (int) speed;
          //if (debugPrint) { Serial.print(" - Accel speedProfile = "); Serial.println(speedProfile); }
        } else if (timeRunning < timeDecel) {
          speedProfile = speedTarget;
          //if (debugPrint) { Serial.print(" - At Speed speedProfile = "); Serial.println(speedProfile); }
          if (speedAtDecel <= -10000) speedAtDecel = speedProfile;
          speed = (float) (timeRunning - timeDecel) / 1000000.0 * (float) decelRate;
          speedProfile = speedAtDecel - (int) speed;
          if (speedProfile < speedMinimum) speedProfile = speedMinimum;
          //if (debugPrint) { Serial.print(" - Decel speedProfile = "); Serial.println(speedProfile); }
        posProfile += (speedProfile * (timeRunning - timeRunningLast)) / 1000000;
        timeRunningLast = timeRunning;
        long perror = posProfile - countEncoder;
        int serror = speedProfile - speedActual;
            // This program uses a PI loop to control speed
            // This loop is NOT tuned.  Meaning testing is required to tune the loop
            // which will provide the best preformance
        pwmLoopI += serror / 4;
        pwmLoopP = serror / 2;
        outputPWM = pwmLoopP + pwmLoopI;
        if (outputPWM < 0) outputPWM = 0;
        if (outputPWM > 254) outputPWM = 254;
        if (debugPrint) {
          Serial.print(",speedProfile:");
          Serial.print(speedProfile);
          Serial.print(",pos_error:");
          Serial.print(perror);
          Serial.print(",speed_error:");
          Serial.print(serror);
          Serial.print(",loopI:");
          Serial.print(pwmLoopI);
          Serial.print(",loopP:");
          Serial.print(pwmLoopP);
  MotionLogic mtrLeft;
  MotionLogic mtrRight;
  // Interupt function for counting left motor encoder pulses
  void encoderIntLeft()  {
    mtrLeft.incrEncoder();
  // Interupt function for counting right motor encoder pulses
  void encoderIntRight()  {
    mtrRight.incrEncoder();
  void setMotorOutputs() {
    if (mtrLeft.getOutputFwd()) digitalWrite(PIN_MTR1_DIR_FWD, HIGH);
    else                        digitalWrite(PIN_MTR1_DIR_FWD, LOW);
    if (mtrLeft.getOutputRev()) digitalWrite(PIN_MTR1_DIR_REV, HIGH);
    else                        digitalWrite(PIN_MTR1_DIR_REV, LOW);
    if (mtrRight.getOutputFwd()) digitalWrite(PIN_MTR2_DIR_FWD, HIGH);
    else                         digitalWrite(PIN_MTR2_DIR_FWD, LOW);
    if (mtrRight.getOutputRev()) digitalWrite(PIN_MTR2_DIR_REV, HIGH);
    else                         digitalWrite(PIN_MTR2_DIR_REV, LOW);
  // Trigger Sonic range finder
  void triggerRangeFinder() {
      digitalWrite(PIN_SONIC_TRIGGER, LOW);
      delayMicroseconds(20);
      digitalWrite(PIN_SONIC_TRIGGER, HIGH);
      delayMicroseconds(10);
      int pcount = pulseIn(PIN_SONIC_PULSE, HIGH);
      sonicDistance = float(pcount) * 0.34 / 2.0;
      //Serial.print(F("Sonic pcount = "));
      //Serial.print(pcount);
      //Serial.print(F("  mm = "));
      //Serial.println(sonicDistance);
  // Used to display fault codes on the built-in LED
  void faultCodeLED(int count) {
    int i = -1;
    flagLED = true;
    toggleLED();
    while (-1) {
      i = count;
      delay(2000);
      while (i > 0) {
        toggleLED();
        delay(300);
        toggleLED();
        delay(300);
        i--;
  // Toggle the Ardunio built in LED each time this function is executed
  void toggleLED() {
    if (flagLED) {
      digitalWrite(PIN_LED,LOW);
      flagLED = false;
      digitalWrite(PIN_LED,HIGH);
      flagLED = true;
  //  This function is called to update the variable information on the display.
  //  Only limited information is updated at a time since the write commands are slow
  void initDisplay() {
    // Display is 20 characters wide by 4 lines
    // 01234567890123456789
    // Cmd:
    // Rng: xxxx.x cm
    // Time: xx.xxx  v.v.vv
    display.clear();
    display.setCursor(0,0);
    display.print(F("Cmd:"));
    display.setCursor(0,2);
    display.print(F("Rng:"));
    display.setCursor(0,3);
    display.print(F("Time:"));
  void updateDisplay() {
    int cmd;
    char buff[12];
    int i;
    int itmp;
    float f;
    switch (printStep) {
      case 0 :
          cmd = cmdQueue.current();
          if (printLastCmd != cmd) {
            display.setCursor(4,0);
            switch (cmd) {
              case VEHICLE_START_WAIT :
                              // 4567890123456789
                display.print(F("WAIT START     "));
              case VEHICLE_START :
                display.print(F("WAIT RELEASE   "));
                display.print(F("FORWARD        "));
              case VEHICLE_TURN_RIGHT :
                display.print(F("TURN RIGHT     "));
              case VEHICLE_TURN_LEFT :
                display.print(F("TURN LEFT      "));
              case VEHICLE_FINISHED :
                display.print(F("FINISHED       "));
              case VEHICLE_STOP :
                display.print(F("STOP           "));
              case VEHICLE_ABORT :
                display.print(F("ABORT          "));
              default :
                display.print(F("***unknown**"));
            printLastCmd = cmd;
      case 1 :
      case 2 :
      case 3 :
          display.setCursor(4,2);
          display.print(sonicDistance,1);
          display.print("cm  ");
      case 4 :
          display.setCursor(6,3);
          f = (float) timerRunTime / 1000000.0;
          display.print(f,3);
      default :
          printStep = -1;
    printStep++;  // increment the print step value to the next sequence step
    toggleLED();
  // The setup() is called once at the power up of the Arduino
    pinMode(PIN_LED, OUTPUT);
    flagLED = false;
    // Only uncomment one motor at a time to use the Serial Plotter function to tune the PID loop
    //mtrLeft.debugOn();
    //mtrRight.debugOn();
    if (mtrLeft.debugState() || mtrRight.debugState()) {
      Serial.println(F("Setup()..."));
    if (DISPLAY_PRESENT) {
      //Serial.println(F("Display init()"));
      display.init();  //initialize the lcd
      display.backlight();  //open the backlight
      display.clear();
      display.print(F("Start Up....."));
    pinMode(PIN_SONIC_TRIGGER,OUTPUT);
    pinMode(PIN_SONIC_PULSE,INPUT);
    pinMode(PIN_PB_START, INPUT_PULLUP);
    pinMode(PIN_MTR1_PWM,OUTPUT);
    pinMode(PIN_MTR2_PWM,OUTPUT);
    pinMode(PIN_MTR1_ENCA, INPUT_PULLUP);
    pinMode(PIN_MTR2_ENCA, INPUT_PULLUP);
    sonicDistance = 0.0;
    timerSonicRange = 0;
    timerDelay = 0;
    attachInterrupt(digitalPinToInterrupt(PIN_MTR1_ENCA), encoderIntLeft, RISING);
    attachInterrupt(digitalPinToInterrupt(PIN_MTR2_ENCA), encoderIntRight, RISING);
    pinMode(PIN_MTR1_DIR_FWD,OUTPUT);
    pinMode(PIN_MTR1_DIR_REV,OUTPUT);
    pinMode(PIN_MTR2_DIR_FWD,OUTPUT);
    pinMode(PIN_MTR2_DIR_REV,OUTPUT);
    speedFwd = 100;
    speedTurn = 100;
    int speedAccel = 100;
    int speedMin  = SPEED_MIN;
    mtrLeft.setParams(speedAccel, speedMin, PIN_MTR1_PWM);
    mtrRight.setParams(speedAccel, speedMin, PIN_MTR2_PWM);
    //Serial.println(F("Initialize Display with background text"));
    if (DISPLAY_PRESENT) { initDisplay(); }
    printStep = 0;
    loadCommandQueue();
    usScanLong = 0;
    usScanAvg = 0;
    timerusScan = 0;
    scanCount = 0;
    usLongResetCount = 0;
    //Serial.println(F("....End Setup"));
    usLast = micros();
  // The following function will execute then exit.  The Ardunio will constantly call this
  // function.  The function should not have delays as this will effect the motor's speed.
    long distance;
    int speed;
    float fspd;
    long ldelta;
    long delayWait;
    int itmp;
      // this block calculates the number microseconds since this function's last execution
    unsigned long current = micros();
    usecElapsed = current - usLast;
    usLast = current;
    if (usecElapsed > usScanLong) usScanLong = usecElapsed;
    timerusScan += usecElapsed;
    scanCount++;
    if (timerusScan > 1000000) {
      usScanAvg = timerusScan / scanCount;
      timerusScan = 0;
      scanCount = 0;
      usLongResetCount++;
      if (usLongResetCount > 10) {
        usScanLong = 0;
    // update motor speed and status
    mtrLeft.updateMotion(usecElapsed);
    mtrRight.updateMotion(usecElapsed);
      // updates the display every 200000us or 0.2 seconds
    if (msTimerPrint > 200000) {
      if (DISPLAY_PRESENT) { updateDisplay(); }
      msTimerPrint = 0;
    msTimerPrint += usecElapsed;
    int newCmd = false;
    if (cmdQueue.firstScan()) {
      newCmd = true;
      //Serial.print(F("New Vehicle Cmd = "));
      //Serial.println(cmdQueue.current());
    int pbStart = !digitalRead(PIN_PB_START);
    if (pbStart) {
      timerPBStartOn  += usecElapsed;
      timerPBStartOff = 0;
      timerPBStartOn = 0;
      timerPBStartOff += usecElapsed;
    if (cmdQueue.current() > VEHICLE_START && cmdQueue.current() < VEHICLE_ABORT) {
      if (timerPBStartOn > 100000) {
        cmdQueue.clear();
        cmdQueue.add(VEHICLE_ABORT);
        mtrLeft.stop();
        mtrRight.stop();
        setMotorOutputs();
    if (flagTimeRun) timerRunTime += usecElapsed;
    switch (cmdQueue.current()) {
          cmdQueue.next();
        timerSonicRange += usecElapsed;
        if (timerSonicRange > 1500000) {
          triggerRangeFinder();
        timerRunTime = 0;
        if (timerPBStartOff > 100000) {
          cmdQueue.next();
          flagTimeRun = 1;
          flagLastMoveFwd = 0;
        if (newCmd) {
          speed = speedFwd;
          setMotorOutputs();
          setMotorOutputs();
          cmdQueue.next();
        if (newCmd) {
          distance = ENCODER_COUNTS_90_DEG;
          speed = speedTurn;
          mtrRight.startMove(distance,speed * -1);
          setMotorOutputs();
          setMotorOutputs();
          cmdQueue.next();
        if (newCmd) {
          speed = speedTurn;
          mtrLeft.startMove(distance,speed * -1);
          setMotorOutputs();
          setMotorOutputs();
          cmdQueue.next();
      case VEHICLE_SET_MOVE_SPEED :
        speedFwd = cmdQueue.getParameter1();
        cmdQueue.next();
      case VEHICLE_SET_TURN_SPEED :
        speedTurn = cmdQueue.getParameter1();
        cmdQueue.next();
      case VEHICLE_SET_ACCEL :
        mtrLeft.setAccel(cmdQueue.getParameter1());
        mtrRight.setAccel(cmdQueue.getParameter1());
        cmdQueue.next();
      default :
        if (newCmd) {
          mtrLeft.stop();
          mtrRight.stop();
          setMotorOutputs();
        flagTimeRun = 0;
        mtrLeft.stop();
        mtrRight.stop();
        setMotorOutputs();
        flagTimeRun = 0;
        if (timerPBStartOff > 200000) {
          loadCommandQueue();
Power problem? Please provide a schematic / wiring diagram (photo of hand-drawn one is fine). How is it all powered.
One test to exclude power issues is to use a simple sketch that will switch both motors on; maybe toggle both motors on/off every 5 seconds.
Here is the link the the wiring diagram that I used:
Both motors work but not together. If left motor is the second command, only left wheel rotates, and if right motor is the second command, then only right wheel rotates. Somehow both the wheels are not rotating together
Here is the code snippet where it does not work
if (newCmd) {
speed = speedFwd;
setMotorOutputs();
