Using two Ultrasonic Sensors HC-SR04
Could anybody please guide me regarding how i use two ultrasonic sensors and get value at the same time.. Please Specify the code and the ports that are to be connected for the two sensors and arduino UNO.. Thanks in Advance
http://forum.arduino.cc/index.php?topic=145816.0
http://code.google.com/p/arduino-new-ping/
Read through for description and explanation. Clicking on the "using only one Arduino pin." link will get you the code. I used this having virtually no experience with arduino or coding, and I got it going OK.
Can anybody assist me what all ports are to be connected for this program…
For Example :
(o)VCC 1 -
(o)Trig 1 -
(o)Echo 1 -
(o)GND 1 -
(o)VCC 2 -
(o)Trig 2 -
(o)Echo 2 -
(o)GND 2 -
// This example code was used to successfully communicate with 15 ultrasonic sensors. You can adjust
// the number of sensors in your project by changing SONAR_NUM and the number of NewPing objects in the
// "sonar" array. You also need to change the pins for each sensor for the NewPing objects. Each sensor
// is pinged at 33ms intervals. So, one cycle of all sensors takes 495ms (33 * 15 = 495ms). The results
// are sent to the "oneSensorCycle" function which currently just displays the distance data. Your project
// would normally process the sensor results in this function (for example, decide if a robot needs to
// turn and call the turn function). Keep in mind this example is event-driven. Your complete sketch needs
// to be written so there's no "delay" commands and the loop() cycles at faster than a 33ms rate. If other
// processes take longer than 33ms, you'll need to increase PING_INTERVAL so it doesn't get behind.
#include <NewPing.h>
#define SONAR_NUM     2 // Number or sensors.
#define MAX_DISTANCE 200 // Maximum distance (in cm) to ping.
#define PING_INTERVAL 33 // Milliseconds between sensor pings (29ms is about the min to avoid cross-sensor echo).
unsigned long pingTimer[SONAR_NUM]; // Holds the times when the next ping should happen for each sensor.
unsigned int cm[SONAR_NUM];         // Where the ping distances are stored.
uint8_t currentSensor = 0;          // Keeps track of which sensor is active.
NewPing sonar[SONAR_NUM] = {     // Sensor object array.
  NewPing(41, 42, MAX_DISTANCE), // Each sensor's trigger pin, echo pin, and max distance to ping.
  NewPing(43, 44, MAX_DISTANCE),
  NewPing(45, 20, MAX_DISTANCE),
  NewPing(21, 22, MAX_DISTANCE),
  NewPing(23, 24, MAX_DISTANCE),
  NewPing(25, 26, MAX_DISTANCE),
  NewPing(27, 28, MAX_DISTANCE),
  NewPing(29, 30, MAX_DISTANCE),
  NewPing(31, 32, MAX_DISTANCE),
  NewPing(34, 33, MAX_DISTANCE),
  NewPing(35, 36, MAX_DISTANCE),
  NewPing(37, 38, MAX_DISTANCE),
  NewPing(39, 40, MAX_DISTANCE),
  NewPing(50, 51, MAX_DISTANCE),
  NewPing(52, 53, MAX_DISTANCE)
  pingTimer[0] = millis() + 75;           // First ping starts at 75ms, gives time for the Arduino to chill before starting.
  for (uint8_t i = 1; i < SONAR_NUM; i++) // Set the starting time for each sensor.
    pingTimer[i] = pingTimer[i - 1] + PING_INTERVAL;
  for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through all the sensors.
    if (millis() >= pingTimer[i]) {         // Is it this sensor's time to ping?
      pingTimer[i] += PING_INTERVAL * SONAR_NUM;  // Set next time this sensor will be pinged.
      if (i == 0 && currentSensor == SONAR_NUM - 1) oneSensorCycle(); // Sensor ping cycle complete, do something with the results.
      sonar[currentSensor].timer_stop();          // Make sure previous timer is canceled before starting a new ping (insurance).
      currentSensor = i;                          // Sensor being accessed.
      cm[currentSensor] = 0;                      // Make distance zero in case there's no ping echo for this sensor.
      sonar[currentSensor].ping_timer(echoCheck); // Do the ping (processing continues, interrupt will call echoCheck to look for echo).
  // The rest of your code would go here.
void echoCheck() { // If ping received, set the sensor distance to array.
  if (sonar[currentSensor].check_timer())
    cm[currentSensor] = sonar[currentSensor].ping_result / US_ROUNDTRIP_CM;
void oneSensorCycle() { // Sensor ping cycle complete, do something with the results.
    Serial.print(i);
    Serial.print("=");
    Serial.print(cm[i]);
    Serial.print("cm ");
It's here https://www.youtube.com/watch?v=1NvpgovTCik
how to assign 1st ultrasonic sensor as primary and using switch assign second ultrasonic sensor as primary and after some time priority assign to 1st ultrasonic sensor.
MADHAVGS:
Please can you state your problem?
What do primary and secondary mean?
Please don’t hijack unrelated topics.
GrooveFlotilla: Please can you state your problem?
Please don't hijack unrelated topics.
what do you mean hijack,better u read my query then reply; if you don't understand the term then don't reply.
