using two ultrasonic sensors
Hi
I am doing a project on automatic switching of room light, by counting the number of persons.
number of persons are stored in variable n.
i couldn’t find the error why the n is not changing.
can anybody suggest solution.
//code
#define t1 2
#define e1 3
#define t2 4
#define e2 5
long d, rs,ls,n;
Serial.begin (9600);
pinMode(t1, OUTPUT);
pinMode(e1, INPUT);
pinMode(t2, OUTPUT);
pinMode(e2, INPUT);
SonarSensor(t1, e1);
rs = d;
SonarSensor(t2, e2);
ls = d;
Serial.print(rs);
Serial.print(" “);
Serial.print(ls);
Serial.print(” ");
Serial.print(n);
if(ls<20){
wait1(n);
goto l1;
if(rs<20){
wait2(n);
goto l1;
l1:if(n>0){
digitalWrite(13, HIGH);
else if(n==0){
digitalWrite(13, LOW);
void SonarSensor(int trigPin,int echoPin)
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
d = pulseIn(echoPin, HIGH);
d = (d/58);
void wait1(int k)
l2: if(rs>20){
rs = d;
ls = d;
Serial.print(ls);
Serial.print(" “);
Serial.print(rs);
Serial.print(” ");
Serial.print(n);
goto l2;
else if(rs<20){
k++;
void wait2(int k)
l3: if(ls>20){
rs = d;
ls = d;
Serial.print(ls);
Serial.print(" “);
Serial.print(rs);
Serial.print(” ");
Serial.print(n);
goto l3;
else if(ls<20){
k–;
Could it be because you never give it a value?
Please use code tags.
Please don't use "goto".
Also, please use functions (Hint only uncompiled, untested)
unsigned long SonarSensor(int trigPin,int echoPin)
  return pulseIn(echoPin, HIGH) / 58;
Also:
  rs = SonarSensor(t1, e1);
  ls = SonarSensor(t2, e2);
It isn't a good idea to take back-to-back readings from sonar sensors like this; you'll often find that distant echoes from the first sensor will be picked up by the second as nearby objects.
