I want to use a ping ultrasonic sensor which has 4 pins (VCC, Trig, Echo, Gnd) with an ATtiny2313, is it possible to use it with that? I need it to turn on and off 2 motors, when distance is 15cm or more, both motors stay on and when its less than that then 1 motor turns off.
You will be able to make some debug prints that could show what's going on.
I can tell you that your distance variable is between 0 and 3, which is probably not what you think
And as AWOL says why use floats ?
You are using almost the entire flash 1982 bytes out of 2048
What else can we use instead of float? Its a variable so I thought we need to use float.
Does it take up a lot of space?
Thanks
@Erni
I already have that core installed how can I make debug prints? What do you mean by the distance variable is between 0 and 3 are you talking about the trig and echo pins? I am confused now…
You could use an integer datatype as a variable, just like the integer variables (why weren't they qualified as "const"?) for the motor pins.
pulseIn returns an unsigned long, IIRC.
A float itself takes only four bytes of RAM, but handling floats requires a lot more code space.
What do you mean by the distance variable is between 0 and 3 are you talking about the trig and echo pins? I am confused now...
Sorry for the confusion. I just tried your sketch and printed the value of your variable: distance
With my ultrasonic sensor the results were between 0 and 3, depending on the distance, but ofcourse you may get other results.
