Using UNO as a programmer avrdude: ser_recv(): programmer is not responding
Arduino: 1.8.13 (Windows 10), Board: "ATtiny25/45/85, ATtiny85, External 8 MHz"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Error while burning bootloader.
option enabled in File -> Preferences.
Im having an issue with AVRDUDE trying to burn a bootloader on Attiny 85 using UNO as a programmer. I tried two different genuine UNO boards and a bunch of Attiny85. I tried three different cables with the same result. I also tried 1.6** versions of Arduino. Finally I tried another laptop with Windows 7 with the same result. UNO works fine on both laptops and I can upload a sketch or bootloader on UNO however when I try to use one UNO to program another Im getting exactly the same message. A couple of years ago I used one of UNOs to burn bootloader on nano clone using Windows 8 and I did not have any problems. I wander if there is some incompatibility between Windows 7 and 10 and AVRDUDE.
Did you upload the File > Examples > 11.ArduinoISP > Arduino ISP sketch to the Uno?
No, it was not in the instruction that I tried to follow but I just tried with both UNO boards and got the same avrdude error message on both WIN7&10.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Sketch uses 4354 bytes (13%) of program storage space. Maximum is 32256 bytes.
Global variables use 482 bytes (23%) of dynamic memory, leaving 1566 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\aiasn\AppData\Local\Temp\arduino_build_477987/ArduinoISP.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x9f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x9f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x9f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x9f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x9f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x9f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x9f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x9f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x9f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x9f
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
