Using Variables from a library in a pde.
Hi all,
This is my first post here, and the first time I’m messing round with libraries and I am stuck…
I want to use multiple variables which I calculate inside a library to use in my main loop. So the question is: How do I “export” variables from the library to the pde?
Searching here and elsewhere on the internet lead me to pointers, but I have no idea what these are. (I`m a mechanical engineer, not a software engineer). Is this the right way to go?
In the end I wanted to create a library to use the Wii nunchuk and motion plus as a IMU. I modified the code as follow:
.PDE code
#include <WiiMU.h>
#include <Wire.h>
WiiMU WiiMU;
WiiMU.startup();
  WiiMU.read
.H code:
  WiiMU.h - Library for Using the Wii nunchuk and Wii motion plus as a IMU.
  based on: arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1248889032/0
  Created by Maarten Lamers, November 12, 2010.
#ifndef WiiMU_h
#define WiiMU_h
#include "WProgram.h"
#include <Wire.h>
class WiiMU
public:
void startup();
void read();
private:
void readData();
void send_zero ();
void initializeSensors();
void calibrateZeroes();
#endif
.CPP code is a bit to long to post here but the idea is that I have 6 varaibles(x,y,z, yaw,pitch,roll) that is want to procces in a filter in the pde file.
Can anyone help me please,
Maarten Lamers
The proper way to do that is to either return the variables by your function such as:
int myfoo = WiiMU.readfoo();
or to declare the variables a properties of your class and access them via the class:
WiiMU.readfoo(); // Calculate internal variables, nothing is returned
// Do something with the variables
int foo = WiiMU.fox + WiiMU.foy;
In both cases, you need to properly declarer your class. Returning your data via a global variables is just a disaster waiting to happen and you shouldn't start learning such horrible coding practices.
For more details, get out your favourite book about C++ and reread the chapter about classes and about functions. It should be chapter 4 or 5.
Korman
Maybe something like this: ? [CODE UNTESTED]
class WiiMU
public:
  typedef float data;
  typedef void (*cb_filter)(data*,data*,data*,data*,data*,data*);
  WiiMU(cb_filter newFilter){
    filter = newFilter;
    x = y = z = yaw = pitch = roll = 0;
  void read(){
    //readData();
    //apply the filter
    filter(&x,&y,&z,&yaw,&pitch,&roll);
protected:
  cb_filter filter;
  data x, y, z, yaw, pitch, roll;
void myFilter(WiiMU::data* x, WiiMU::data* y, WiiMU::data* z, WiiMU::data* yaw, WiiMU::data* pitch, WiiMU::data* roll) {
  //do what ever with the datas
  //REMEMBER, if you change the value here, they will change in the library as well!
WiiMU wiiMU(myFilter);
  wiiMU.read();
If you want pre-read / post-read filters you can easily extend to support that as well.
