Using variables in a loop
I’m trying to use a loop to avoid duplicating allot of code over and over. Basically when a pin goes HIGH (or is held HIGH) I need to play a sound.
So far I’ve tried…
// loop from the lowest pin to the highest:
for (int thisPin = 0; thisPin < pinCount; thisPin++) {
if ((pinplay[thisPin] == 0) && (digitalRead(pin[thisPin]) == HIGH)) {
doplay([thisPin]);
pinplay[thisPin] = 1;
if (digitalRead(pin[thisPin]) == LOW) {
pinplay[thisPin] = 0;
void doplay (int value) {
myDFPlayer.play(value);
//value of 1 would play 0001.mp3
…but [thisPin] doesn’t seem to actually input the number in all instances? I’m getting compile error: expected { before ) token
Any other way to accomplish this?
Try this instead:
doplay(thisPin);
You might also be interested in my DFPlayer library if your project has a speed requirement: library.
