Using VSCode/Platform IO: collect2.exe: error: ld returned 1 exit status
Hello, not sure if this is the correct place for this but I am trying to use platformIO through VS Code for my arduino as Arduino's IDE is not letting me install the board.
I am using an ESP32-S3 TFT from adafruit and I am receiving this error from the terminal:
.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: cannot find  Inc\Documents\Laser Bucket Alignment Fixture\Laser Bucket Tool\Laser Bucket Tool\.pio\build\adafruit_feather_esp32s3_tft\firmware.map: No such file or directory
*** [.pio\build\adafruit_feather_esp32s3_tft\firmware.elf] Error 1
Here's the whole log:
Processing adafruit_feather_esp32s3_tft (platform: espressif32; board: adafruit_feather_esp32s3_tft; framework: arduino)
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/adafruit_feather_esp32s3_tft.html
PLATFORM: Espressif 32 (6.1.0) > Adafruit Feather ESP32-S3 TFT
HARDWARE: ESP32S3 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
 - framework-arduinoespressif32 @ 3.20007.0 (2.0.7)
 - tool-esptoolpy @ 1.40500.0 (4.5.0)
 - tool-mkfatfs @ 2.0.1
 - tool-mklittlefs @ 1.203.210628 (2.3)
 - tool-mkspiffs @ 2.230.0 (2.30)
 - toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
 - toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Warning! An extra UF2 bootloader image is already added!
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 34 compatible libraries
Scanning dependencies...
Dependency Graph
|-- STM32duino VL53L4CD @ 1.0.2
|-- Wire @ 2.0.0
Building in release mode
Compiling .pio\build\adafruit_feather_esp32s3_tft\src\main.cpp.o
Linking .pio\build\adafruit_feather_esp32s3_tft\firmware.elf
c:/users/nhoong/.platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: cannot find  Inc\Documents\Laser Bucket Alignment Fixture\Laser Bucket Tool\Laser Bucket Tool\.pio\build\adafruit_feather_esp32s3_tft\firmware.map: No such file or directory
========================================================================================== [FAILED] Took 8.09 seconds ==========================================================================================
 *  The terminal process "C:\Users\nhoong\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
The code that I am trying to compile is
/* Includes ------------------------------------------------------------------*/
#include <Arduino.h>
#include "Wire.h"
/* Setup ---------------------------------------------------------------------*/
  Serial.println("Hello World");
If I don't include Wire.h it gives me this error.
Very new to Arduinos, does anyone understand what's going on?
