I am using the Mega 2560 in an application where I'm running a timer, and I am getting infrequent "freezes" or hang ups.
Few questions to throw out there...
I found a watchdog tutorial for Mega and I will look into using this to sort out why it's freezing, but before I get too far...
My timer counts down from 20-45min down to zero depending on setting. It's on every day, although primarily used during the day.
My ideal scenario to fix this would be use the watchdog and somehow recover from a freeze and not reset. I would like to keep my hardware as-is and not have to add external memory to remember how much time was left or anything like that if possible.
Sketch uses 4% storage space, global variables 17% dynamic memory, leaving 6786 bytes for local variables.
I'll see about blurring out some areas of the code if its needed for sharing... prefer to not post the whole thing. Also it's the longest thing I've ever programmed and I'm a newbie so I probably broke all the best practices out there
Thanks in advance!
