Im looking back into WDT use for power savings. I want to make sure I understand this code properly. This uses the 8 second max setting but multiplies it by nbr_remaining in order to go above 8 seconds, so 5 times would be 40 seconds.
So this will start up, blink 2x, sleep for 40 seconds, blink 3x, sleep for 40 seconds, blink 3x...etc:
#include <avr/wdt.h> // library for default watchdog functions
#include <avr/interrupt.h> // library for interrupts handling
#include <avr/sleep.h> // library for sleep
#include <avr/power.h> // library for power control
int nbr_remaining;
#define led 13
ISR(WDT_vect){
// not hanging, just waiting
// reset the watchdog
wdt_reset();
void configure_wdt(void){
cli(); // disable interrupts for changing the registers
MCUSR = 0; // reset status register flags
// Put timer in interrupt-only mode:
WDTCSR |= 0b00011000; // Set WDCE (5th from left) and WDE (4th from left) to enter config mode,
// using bitwise OR assignment (leaves other bits unchanged).
WDTCSR = 0b01000000 | 0b100001; // set WDIE: interrupt enabled
// clr WDE: reset disabled
// and set delay interval (right side of bar) to 8 seconds
sei(); // re-enable interrupts
void sleep(int ncycles){
nbr_remaining = ncycles; // defines how many cycles should sleep
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
power_adc_disable();
while (nbr_remaining > 0){ // while some cycles left, sleep!
sleep_mode();
// CPU is now asleep and program execution completely halts!
// Once awake, execution will resume at this point if the
// watchdog is configured for resume rather than restart
// When awake, disable sleep mode
sleep_disable();
// we have slept one time more
nbr_remaining = nbr_remaining - 1;
// put everything on again
power_all_enable();
void setup(){
// use led 13 and put it in low mode
pinMode(led, OUTPUT);
digitalWrite(led, LOW);
// configure the watchdog
configure_wdt();
// blink twice
digitalWrite(led, HIGH);
void loop(){
// sleep for a given number of cycles (here, 5 * 8 seconds) in lowest power mode
sleep(5);
// usefull stuff should be done here before next long sleep
// blink three times
