Using while loops to PWM an led controlled by a button
so I have been trying for quite a few hours now to figure out this project with very little to no progress at all. here is my task or problem statement.
Problem Statement: First program: solve this problem using only "while" loops inside the loop function. The first program will loop eight times – i.e. for eight button pushes for a button on pin #2. Connect an LED to pin #3 (PWM pin). The brightness of the LED will be adjusted using the PWM control, each time the button (pin-2) is pushed. First button push – LED goes from Off to 100% brightness. Second button push will decrease brightness to 60%. Third button push will decrease LED brightness to 30%. Fourth button push will turn Off the LED. The while loop will count eight button pushes, cycling through the LED brightness levels twice. After eight button pushes, exit the while loop and enter an infinite while loop – i.e. trap the program in an infinite loop. Second program, solve the program above (first program) using only "for" loops instead
of while loops.
Im having trouble really even getting started, the previous task I did using If statements was a lot easier.
any pointers or tips, or any kind of assistance at all would be greatly appreciated.
Is this project school work?
Post what you've written so far.
Don't forget, when posting, use tags by clicking </> .
ArduinoForum
Do you have a schematic diagram to share?
What have you done previously as far as seeing buttons and reacting to them?
Post your best attempt so far, whatever you got.
Oh, welcome to the community.
a7
I would use neither while or for loops as they block execution. I try to write code that is non-blocking and so is responsive to input.
I would use the state change detection method to count button presses and use the current count to choose a LED brightness value to send to a PWM pin.
See also state change detection for active low input.
Yes this project is school work, would like help but not answers (like I don't want it done for me)
const int ledPin = 3;
const int buttonPin = 2;
int preState = 0;
int buttonState = 0;
int counterNumber = 0;
  pinMode(buttonPin,INPUT_PULLUP);
  pinMode(ledPin,OUTPUT);
 buttonState = digitalRead(buttonPin);
  while (buttonState == HIGH && preState == 0){
    analogWrite (ledPin, 255);
    preState = 1;
I had more code but it wasn't working right so I have been attempting starting over from the beggining. right now with this code it doesn't acknowledge that i pressed a button the led is just always on.
i posted my code below, it's not much.
i previously wrote a program that counted button presses using if statements, and then terminated the code using a while loop at the end, that project was pretty simple. however im confined to only using while loops in my first program and im not really familiar with how to use them at all.
No, but the OP is being led through some kind of learning process and for now will be writing programs to look back at one day and marvel.
You wouldn't finish with an infinite loop either!
a7
Without a schematic we can't know how your button is wired, how you LED is wired, to what &c.
No word salad, please. Just hand draw your circuit and post a celly.
a7
I get that, but had to say something. The state change detection should still be of value.
I just took some pictures of my board, I hope that helps.
Not much. Not gonna squint at a few snaps. Srsly, just draw the components, and lines between them to show what wires hook what to what.
Take a few minutes, google "schematic diagram", choose images and try you best.
It is never too early to learn, and this basic level of diagram will not take long to do.
You will find it is the way ppl share information about the hardware. And it will always be among the top 2 or 3 things those who want to help will ask for.
Besides being a good thing to have yourself before you start plugging up you circuit.
a7
hope this works a little better?
write a part of the code and the rest you must complete.
where you have ....... is for you to continue and see if you understand the logic.
Good luck.
//  https://forum.arduino.cc/t/using-while-loops-to-pwm-an-led-controlled-by-a-button/965889/5
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(ledPin, OUTPUT);
  counterNumber = 1;                      // Refresh my counter
  while (counterNumber < 9 )              // Do  8 Times
    if (digitalRead(buttonPin) == LOW)    // Verify if button was pressed
      delay(30);                          // Avoid bouncing
      if (digitalRead(buttonPin) == LOW)  // Verify if button stay pressed
        counterNumber++;                  // Increment my counter
    if (counterNumber == 1)               // If my counter is 1
      analogWrite (ledPin, 255);          // Light LED full
  if ( counterNumber == 2)
  if ..........
In the code in this post (#5) you never update buttonState inside the while loops. The last knowledge we have of buttonState is that before the while loop was entered - and so it will stay.
Something inside the while loop must change to be able to break out.
int preState = 0;
  while (counterNumber < 9){
    buttonSmash();
void buttonSmash(){
    counterNumber = 1;
    if (buttonState == LOW && counterNumber == 1 && preState == 0){
      analogWrite(ledPin, 255);
      counterNumber++;
      preState = 1;
     if (buttonState == LOW && counterNumber == 2 && preState == 0){
      analogWrite(ledPin, 150);
      counterNumber++;
      preState = 1;
    if (buttonState == LOW && counterNumber == 3 && preState == 0){
      analogWrite(ledPin, 76);
      counterNumber++;
      preState = 1;
    if (buttonState == LOW && counterNumber == 4 && preState == 0){
      analogWrite(ledPin, 0);
      counterNumber++;
      preState = 1;
    if (buttonState == HIGH){
      preState = 0;
So this is one version I had because I wasn't sure if i was allowed to use if statement in my loop. so this is what I came up with, but it only turns the led on to 100% on the first button press and doesn't change after any other button press.
  counterNumber = 1;
      delay(150);
        counterNumber++;
   if (counterNumber == 2)
    analogWrite(ledPin, 155);
   if (counterNumber == 3)
   if (counterNumber == 4)
   if (counterNumber == 5)
   if (counterNumber == 6)
   if (counterNumber == 7)
   if (counterNumber == 8)
I also tried it with the sample of code you provided, however my full code doesn't seem to light the LED at all. not sure what im doing wrong on either versions of the code.
Actually, no better at all.
Part of the learning process is to understand - and practice - what a "schematic diagram" is. :grin:
cool I really get that I do, but that's not my current task on hand.
if it's not 'good' enough for you to provide meaningful help with, just don't respond, I don't have the time to sit down and practice my schematic diagrams as I am currently practicing this problem statement.
