I'm struggling to get a stepper motor function to run after sending a command via the Wire.h library. I'm controlling the motors with AccelStepper, and driving this between two Arduino Mega boards.
I'm using Wire.onReceive() function to try and initiate the motor stepping function. After sending the trigger from the Master device, the driver board LEDs light up, and I can hear the motor buzzing, but the motor does not step.
When not driving this through I2C, but calling the function directly in the loop() of the Slave, the motor steps as expected.
My best guess is that using the Wire.h function is impacting the timing for the AccelStepper step execution. But I've not been able to find any clues searching the forum. Appreciate the advice!
Master Code:
#include<Wire.h>
char user_input;
Wire.begin();
while (Serial.available()) {
user_input = Serial.read();
if (user_input == '1'){
Wire.beginTransmission(1);
Wire.write(int(0));
Wire.endTransmission();
else {
Serial.println("Invalid option entered.");
Slave Code:
(I have an array of 12 motors defined below, but am only trying to step motor-0 for this demo)
#include <AccelStepper.h>
#include<Wire.h>
#define HALFSTEP 8
uint8_t MotorPins[][12] = {
{2, 6, 10, 14, 47, 22, 23, 30, 31, 38, 39, 48},
{3, 7, 11, 15, 49, 24, 25, 32, 33, 40, 41, 46},
{4, 8, 12, 16, 51, 26, 27, 34, 35, 42, 43, 52},
{5, 9, 13, 17, 53, 28, 29, 36, 37, 44, 45, 50}};
const uint8_t NumberOfSteppers = (sizeof(MotorPins[0]) / sizeof(MotorPins[0][0])); // returns #cols from MotorPins array
AccelStepper *stepperPtrArray[NumberOfSteppers];
float MaxSpeed = 1200;
float Accel = 1000;
float Speed = 1400;
long RunOut = -2048 * 1.85;
uint8_t x;
uint8_t StepperNumber = 0; // Selecting the first motor in the above array for this demo
for (x = 0; x < NumberOfSteppers; x++){
stepperPtrArray[x] = new AccelStepper(HALFSTEP, MotorPins[0][x], MotorPins[2][x], MotorPins[1][x], MotorPins[3][x]);// NOTE: The sequence 1-3-2-4 is required for proper sequencing of 28BYJ48
stepperPtrArray[x]->setMaxSpeed(MaxSpeed);
stepperPtrArray[x]->setAcceleration(Accel);
stepperPtrArray[x]->setSpeed(Speed);
Wire.begin(1);
Wire.onReceive(receiveEvent); // I've also tried having this call the StepMotorForward() directly, but results are the same
//receiveEvent(); // This is here to verify the step function works correctly outside of Wire.onReceive();
void receiveEvent(){
while(Wire.available())
StepperNumber = Wire.read();
StepMotorForward();
void StepMotorForward() {
stepperPtrArray[StepperNumber]->setCurrentPosition(0);
stepperPtrArray[StepperNumber]->moveTo(-RunOut);
stepperPtrArray[StepperNumber]->setSpeed(Speed);
while (abs(stepperPtrArray[StepperNumber]->distanceToGo()) > 0) {
stepperPtrArray[StepperNumber]->runSpeedToPosition();
stepperPtrArray[StepperNumber]->disableOutputs();
