using Xbee library with 2pcs xbee S2 receiving garbage data.
Hi…I’m testing the xbee library by Andrew. Following the tutorial from https://code.google.com/p/xbee-api/wiki/XBeeConfiguration. I think I have it right.
General setup:
Coordinator Router
PAN ID 1AAA 1AAA
CH 17 17
NI Coordinator Router1
Baudrate 9600 9600
Coordinator to PC and Router1 to Arduino Uno
After loading the given example Series2_Tx to arduino gives me the following result(non readable characters)…please see attached image.
Can you help me point out what I’m doing wrong in the process?
Thanks in advance.
I change to using CoolTerm and load different program to arduino. Below is what I get.
~....}3..@..n...Hello World
R~.+..}3..@..n...I saw what you did last night
R
Sorry if I’m still new to this. But my question will be…when using the xbee library it gives special characters symbols, are these normal?
Thanks in advance
But my question will be...when using the xbee library it gives special characters symbols, are these normal?
Try re-reading the first line in your previous post, and use that information to decide whether we can really answer this question.
