Hello. I hope someone can help.
My Arduino knowledge is currently pretty basic, but I am trying to use XBee RSSI values to control Mozzi synths, so that various envelopes or filters change when 3D objects are further apart of closer together. There are 4 objects, each with an XBee inside.
I am trying to use
rssiDur = pulseIn(digitalPin, LOW, 200);
as mentioned here - Notion – The all-in-one workspace for your notes, tasks, wikis, and databases., but don't know how to use / adapt this to control synths.
I have some code that I had a lot of help with that seems to read the fact that there RSSI data there, but it doesn't seem to change the sound when the distance changes, just when it detects another XBee transmitting.
#include <MozziGuts.h>
#include <Oscil.h> // oscillator
#include <tables/cos2048_int8.h> // table for Oscils to play
#include <AutoMap.h> // maps unpredictable inputs to a range
// desired carrier frequency max and min, for AutoMap
const int MIN_CARRIER_FREQ = 22;
const int MAX_CARRIER_FREQ = 440;
// desired intensity max and min, for AutoMap, note they're inverted for reverse dynamics
const int MIN_INTENSITY = 700;
const int MAX_INTENSITY = 10;
AutoMap kMapCarrierFreq(0,1023,MIN_CARRIER_FREQ,MAX_CARRIER_FREQ);
AutoMap kMapIntensity(0,1023,MIN_INTENSITY,MAX_INTENSITY);
const int KNOB_PIN = 0; // set the input for the knob to analog pin 0
const int LDR_PIN = 1; // set the input for the LDR to analog pin 1
Oscil<COS2048_NUM_CELLS, AUDIO_RATE> aCarrier(COS2048_DATA);
Oscil<COS2048_NUM_CELLS, AUDIO_RATE> aModulator(COS2048_DATA);
int mod_ratio = 3; // harmonics
long fm_intensity; // carries control info from updateControl() to updateAudio()
//Constants
const int ledPin = 3; //Led to Arduino pin 3 (PWM)
//Variables
bool started= false;//True: Message is strated
bool ended = false;//True: Message is finished
char incomingByte ; //Variable to store the incoming byte
char msg[3]; //Message - array from 0 to 2 (3 values - PWM - e.g. 240)
byte index; //Index of array
int rssiDur = 0;
int rssiMapped =0;
bool calib = false;
bool calib_top = false;
int base_value= 0;
int top_value=0;
//Start the serial communication
Serial.begin(9600); //Baud rate must be the same as is on xBee module
pinMode(ledPin, OUTPUT);
pinMode(6, OUTPUT);
calib = true;
calib_top = true;
startMozzi(); // :))
void updateControl(){
// read the knob
//int knob_value = mozziAnalogRead(KNOB_PIN); // value is 0-1023
rssiDur = pulseIn(5, LOW, 200);
rssiMapped = map(rssiDur, 10, 40, 0, 1023);
Serial.print("raw RSSI : ");
Serial.println(rssiDur);
Serial.print("RSSI mapped : ");
Serial.println(rssiMapped);
//delay(100);
// map the knob to carrier frequency
int carrier_freq = kMapCarrierFreq(rssiMapped);
//calculate the modulation frequency to stay in ratio
int mod_freq = carrier_freq * mod_ratio;
// set the FM oscillator frequencies to the calculated values
aCarrier.setFreq(carrier_freq);
aModulator.setFreq(mod_freq);
// read the light dependent resistor on the Analog input pin
int light_level= mozziAnalogRead(LDR_PIN); // value is 0-1023
fm_intensity = kMapIntensity(light_level);
int updateAudio(){
long modulation = fm_intensity * aModulator.next();
return aCarrier.phMod(modulation); // phMod does the FM
//delay(100);
if(rssiDur != 0){
digitalWrite(6, HIGH);
}else{
digitalWrite(6,LOW);
audioHook();
while (Serial.available()>0){
//Read the incoming byte
incomingByte = Serial.read();
//Start the message when the '<' symbol is received
if(incomingByte == '<')
started = true;
index = 0;
msg[index] = '\0'; // Throw away any incomplete packet
//End the message when the '>' symbol is received
else if(incomingByte == '>')
ended = true;
break; // Done reading - exit from while loop!
//Read the message!
if(index < 4) // Make sure there is room
msg[index] = incomingByte; // Add char to array
index++;
msg[index] = '\0'; // Add NULL to end
if(started && ended)
int value = atoi(msg);
//analogWrite(ledPin, value);
Serial.println(value); //Only for debugging
if(calib_top){
if(value == 0){
top_value = rssiMapped;
Serial.println(top_value);
calib_top = false;
index = 0;
msg[index] = '\0';
started = false;
ended = false;
Any help at all would be appreciated, bearing in mind my basic level of knowledge. I did the Mozzi introductory tutorials, so I get how to wire stuff together, but am not so clear on how to adapt the code.
Thank you in advance.
