Hello, in a previous post, I found that the 48MHz clock source was a bit too error prone for very exact timing, but that using XOSC32K was a great way to get really accurate timing, with the constraint of that relatively low frequency.
I noticed that the SAMD21G18A (used on the Zero), does have another external clock source, which can take a crystal of 0.4-32MHz. I figured this could be a great way to get accurate timing at a much higher frequency. So I developed my own board with the usual 32KHz crystal as well as a 25MHz crystal between pins D2 (PA14) and D5(PA15) (according to the datasheet those are the input/output for XOSC), in the hopes of testing this out.
I was wondering if anyone else has used XOSC and can point me in the right direction as far as using it.
I actually resolved this one. One can setup XOSC with:
//this sets up the external OSC.
SYSCTRL->XOSC.reg = 0
| SYSCTRL_XOSC_XTALEN
| SYSCTRL_XOSC_STARTUP(0xF) // 32768
| SYSCTRL_XOSC_AMPGC
| SYSCTRL_XOSC_ENABLE
while (GCLK->STATUS.reg & GCLK_STATUS_SYNCBUSY);
then it can be attached to a clock like:
REG_GCLK_GENCTRL = GCLK_GENCTRL_IDC | // Set the duty cycle to 50/50 HIGH/LOW
GCLK_GENCTRL_GENEN | // Enable GCLK4
// GCLK_GENCTRL_SRC_XOSC |
GCLK_GENCTRL_ID(4); // Select GCLK4
while (GCLK->STATUS.bit.SYNCBUSY); // Wait for synchronization
Now that it's a clocked signal you can divide it down/use it like any other clock signal.
So if you need tight high frequency timing (up to 32MHz) just throw a crystal between PA14 and PA15 (with load caps), add the above code to your setup routine and you should be good to go.
I tested this with the SAMD21G18A and a 25MHz, 18pF crystal; and it worked perfectly
