hi, i was wondering if it were at all possible to use an Arduino Yun with a 4GB SD card to run an OCR program, like OpenCV or Tessaract. I'm working on a project and haven't found much headway. Some who say they can and some who say they can't. i'm trying to read only one character from a picture as an identifier. The 4GB SD card is used to upgrade the disk space for the Yun. any ideas?
clarkd777:
@clarkd777,
I reviewed the Yún Software Packages. There is no OpenCV or Tessaract, listed.
Google: openwrt opencv
OpenCV: Open Source Computer Vision Library
Google: site:forum.arduino.cc yun opencv
OpenCV on Yun
SonnyYu
I port OpenCV to Yun-Openwrt. OpenCV is very cpu intensive application. if detection takes 0.2 sec at laptop. It could take 0.8 sec at Yun since it only has AR9331 CPU/400Mhz. The speed is only major issue.
What you would like to do?
Jesse
sonnyyu:
Arduino Yun's SoC is AR9331. It has neither FPU nor GPU.Raspberry Pi's SoC is a Broadcom BCM2835. This contains an ARM1176JZFS, with FPU, running at 700Mhz, and a Videocore 4 GPU. The GPU is capable of BluRay quality playback, using H.264 at 40MBits/s. It has a fast 3D core accessed using the supplied OpenGL ES2.0 and OpenVG libraries.
Post same question at Raspberry Pi forum?
thanks for the help!
