I am currently attempting to build a prototype proof of concept for a 24hour fish tank monitor that would send alerts to the owner if temperatures got too hot or too cold - the zentser app works really well for this so the challenging part is building a compatible sensor that will communicate with the app.
I am using an ESP8266 board (NodeMCU v3) and a DS18b20 submersible temperature sensor.
I have the example code for the ESP board using a DHT sensor
#include <Zentser_ESP_SDK.h>
/*#include <YOUR_SENSORS_LIBRARY> */
#include <DHT.h>
char const *ssid = "YOUR_WIFI";
char const *wiFiPassword = "YOUR_WIFI_PASSWORD";
// Replace on generated code from Zentser Application
// --- START ---
static const char caCert[] PROGMEM = R"EOF(
/* CA CERTIFICATE */
)EOF";
static const char cert[] PROGMEM = R"KEY(
/* CERTIFICATE */
)KEY";
static const char privateKey[] PROGMEM = R"KEY(
/* PRIVATE_KEY */
)KEY";
String deviceId = "YOUR_DEVICE_ID"; // Zentser Device ID
Sensor sensors[] {
Sensor("YOUR_SENSOR_ID_0", "Temperature (F)"),
Sensor("YOUR_SENSOR_ID_1", "Humidity (%)"),
Sensor("YOUR_SENSOR_ID_2", "Heat Index (F)"),
// --- END ---
AWSConfig aws = AWSConfig(deviceId, sensors); // init AWS function
// Initialize Your sensor
// Digital pin connected to the DHT sensor
uint8_t DHTPIN = 14; //D5
// Uncomment whatever DHT sensor type you're using
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Initialize DHT sensor
DHT dht(DHTPIN, DHTTYPE);
// Function to connect to WiFi
void connectToWiFi() {
Serial.print("\nConnecting to AP ...");
WiFi.begin(ssid, wiFiPassword);
Serial.print(".");
Serial.println("\nConnected to AP");
// initial function at starting your microcontroller (ESP, Arduino, etc)
Serial.begin(115200); // init serial for logging
connectToWiFi(); // call function to start WiFi connection
//get AWS certificates to authenticate sending sensor data
aws.setupAWSCertificates(cert, privateKey, caCert);
// connect and start your sensor
pinMode(DHTPIN, INPUT);
dht.begin();
// main loop for microcontroller where you will collect and send sensor data
// Check Wifi connection is still active
if (WiFi.status() != WL_CONNECTED) {
connectToWiFi();
// MODIFY to get sensor readings from hardware connected to your microcontroller
float t = dht.readTemperature(true);
float h = dht.readHumidity();
float hIdx = dht.computeHeatIndex(t, h);
Serial.printf("t = %6.2f; h = %6.2f; heatIndex = %6.2f\n", t, h, hIdx);
sensors[0].value = t;
sensors[1].value = h;
sensors[2].value = hIdx;
aws.sendSensorsTelemetry();
// check that we're not bombarding Zentser with too much data
// don't want to bring the system down in unintended DDoS attack
aws.delayNextRead();
and for the DS18B20 sensor from the DallasTemperatures Library
// Include the libraries we need
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
* The setup function. We only start the sensors here
void setup(void)
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
* Main function, get and show the temperature
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
// After we got the temperatures, we can print them here.
// We use the function ByIndex, and as an example get the temperature from the first sensor only.
float tempC = sensors.getTempCByIndex(0);
// Check if reading was successful
if(tempC != DEVICE_DISCONNECTED_C)
Serial.print("Temperature for the device 1 (index 0) is: ");
Serial.println(tempC);
Serial.println("Error: Could not read temperature data");
However in trying to combine the two I cannot find where the ESP board decides what to send to the app or where the DS18B20 decides what to send to the serial monitor so I cannot find a way to make these two parts match up
Anyone have any experience with this?
