uspeech serial monitor
Once I run the debugging code I open my serial monitor and when I press the keys such as c into the serial monitor to check each aspect (such as the volume or power of the mic), no values are given back. Any help is appreciated.
    #include <uspeech.h>
signal voice(A0);
char option = 0;
uint32_t power(uint32_t base, uint32_t exp);
#if 0
    int minVolume;  /*!< This is the highest audio power that should be considered ready */
    int fconstant;  /*!< This is the threshold for /f/, configure it yourself */
    int econstant;  /*!< This is the threshold for /ee/, /i/, configure it yourself */
    int aconstant;  /*!< This is the threshold for /a/ /o/ /r/ /l/, configure it yourself */
    int vconstant;  /*!< This is the threshold for /z/ /v/ /w/, configure it yourself */
    int shconstant; /*!< This is the threshold for /sh/ /ch/, above this everything else is regarded as /s/ */
    bool f_enabled; /*!< Set this to false if you do not want to detect /f/s */
    int amplificationFactor; /*!<Amplification factor: Adjust as you need*/
#endif
    analogReference(EXTERNAL);
    voice.f_enabled = true;
    voice.fconstant = 240;
    voice.econstant = 2; //3; //1 2;
    voice.aconstant = 4; //5; //2 4;
    voice.vconstant = 6; //7; //3 6;
    voice.shconstant = 8; //4;
    voice.amplificationFactor = 10;
    voice.micPowerThreshold = 80;
    voice.scale = 8;
#if 0
    while (1) {
        uint16_t sig = analogRead(A0);
	Serial.println(sig);
	delay(100);
#endif
    Serial.println(F("Calibrating"));
    voice.calibrate();
    Serial.print(F("Calibrated at "));
    Serial.println(voice.calib);
    Serial.println(F("Ready"));
uint16_t lastMicPower=0;
char lastPhoneme = ' ';;
uint16_t lastCoeff=0;
uint16_t lastPower=0;
uint32_t lastChange = 0;
uint32_t startUsec = 0;
uint8_t col=0;
char buf[80];
struct history_s {
    int micPower;
    int coeff;
    char phoneme;
    char f_phoneme;
    uint32_t usecs;
} history[80];
uint32_t power(uint32_t base, uint32_t ex)
    if (ex == 0)
	return 1;
    else if (ex % 2)
	return base * power(base, ex - 1);
    else {
	int temp = power(base, ex / 2);
	return temp * temp;
void pad(uint32_t value, uint8_t places)
    uint32_t padValue = power(10, places);
    while (value < padValue) {
        Serial.print(' ');
	padValue /= 10;
    Serial.print(value);
    char phoneme = voice.getPhoneme();
    if (option==0) {
	Serial.println(F("uSpeech debug tool--------"));
	Serial.println(F(" Press 'f' if you wish to calibrate/check the f algorithm (micPower)"));
	Serial.println(F(" Press 'p' if you wish to calibrate/check the getPhoneme"));
	Serial.println(F(" Press 'v' if you wish to calibrate/check the volume of your microphone"));
	Serial.println(F(" Press 'c' if you wish to calibrate/check the coeff"));
	option = 1;
    if (Serial.available() > 0) {
	option = Serial.read();
    switch (option) {
    case 'f': {
	uint16_t micPower = voice.micPower;
	if (micPower != lastMicPower) {
	    Serial.print(F("micPower: "));
	    Serial.println(micPower);
	    lastMicPower = micPower;
    case 'p': {
	if (phoneme != lastPhoneme || phoneme != ' ') {
	    if (col == 0) {
		startUsec = micros();
	    lastPhoneme = phoneme;
	    buf[col] = phoneme;
	    history[col].phoneme = phoneme;
	    history[col].f_phoneme = voice.phoneme;
	    history[col].coeff = voice.testCoeff;
	    history[col].micPower = voice.micPower;
	    history[col].usecs = micros() - startUsec;
	    if (++col >= sizeof(buf)-1) {
	        buf[col] = 0;
		Serial.println(F("phonemes"));
		for (uint8_t ind=0; ind<col; ind++) {
		    Serial.print(F("    "));
		    pad(history[ind].usecs,5);
		    Serial.print(F(": '"));
		    Serial.print(history[ind].phoneme);
		    Serial.print('\'');
		    Serial.print(F(" ("));
		    Serial.print(history[ind].coeff);
		    Serial.print(',');
		    Serial.print(history[ind].micPower);
		    Serial.println(')');
		Serial.print(F("phoneme sequence: \""));
		Serial.print(buf);
		Serial.println('"');
	        col = 0;
	    lastChange = millis();
	if (col && ((millis() - lastChange) > 50)) {
	    buf[col] = 0;
		//Serial.print(history[ind].usecs);
		Serial.print('\'');
		Serial.print(',');
		Serial.print(')');
		if (history[ind].phoneme == 'f') {
		    Serial.print(" '");
		    Serial.print(history[ind].f_phoneme);
		    Serial.println('\'');
	    col = 0;
	    Serial.print(buf);
	    Serial.println(F("-----------------------------"));
    case 'v': {
	uint16_t power = voice.power();
	if (power != lastPower) {
	    Serial.print(F("power:"));
	    Serial.println(power);
	    lastPower = power;
    case 'c': {
	uint16_t coeff = voice.testCoeff;
	if (coeff != lastCoeff) {
	    Serial.print(F("coeff: "));
	    Serial.println(coeff);
	    lastCoeff = coeff;
    case 1:
    default:
	option = 0;
	if (col) {
	    col = 0;
Did you ever get this code to work? I just uploaded it and when I opened the serial monitor received a bunch of random characters and did not see any of the options shown in the uSpeech tutorial.
Angelo
