can i please get some advice on the ustepper limit detection sketch as the motor doesn't stop...it crashes.
i have looked on git hub and cant make head nor tails out of it.
i'm attempting to make a linear rail with limit detection for the home position
any help appreciated
Much easier for everyone if you post the program here. This seems to be it
#include <uStepper.h>
#define MICROSTEP 16//microstep setting of uStepper
#define RES (200.0*MICROSTEP)/360.0//calculate step pr. degree
#define STEPPRMM 53.55//step pr. mm for the rail used in the demo
#define MMPRSTEP 1/STEPPRMM//mm pr. step
#define MMPRDEG MMPRSTEP*RES//mm pr. degree
uStepper stepper;
stepper.setup();
stepper.setCurrent(15.0);//use software current setting
stepper.setMaxAcceleration(20000);
stepper.setMaxVelocity(4000);
float limit()
int checks=0;
float pos=0.0;
stepper.runContinous(CCW);
while(checks < 3)//allows for 2 checks on movement error
pos = abs(stepper.encoder.getAngleMoved()-(stepper.getStepsSinceReset()*0.1125));//see current position error
if(pos<5)//if position error is less than 5 steps it is okay...
checks=0;
else //if position error is 5 steps or more, count up checks
checks++;
checks=0;//reset checks for next endstop detection
stepper.hardStop(SOFT);//stop motor without brake
stepper.moveSteps(5*STEPPRMM, CW, SOFT);//back off with 5 mm
while(stepper.getMotorState())//wait for motor to finish move
delay(1);//because Arduino does not accept the empty while loop for some reason....
stepper.encoder.setHome();//set new home position
stepper.runContinous(CW);//do check in opposite direction
checks=0;
checks++;
stepper.moveSteps(5*STEPPRMM, CCW, SOFT);//back off with 5 mm
pos = stepper.encoder.getAngleMoved();//read current position
stepper.moveSteps((pos*RES)/2, CCW, SOFT);//go to center
return pos;//return max position
Serial.println(limit()*MMPRDEG);//find end positions and read out the recorded end position
stepper.setup(PID,SIXTEEN,10,5,2.0,2.0,0.6);//enable PID
stepper.setCurrent(100.0);//use software current setting
while(1);
I was under the impression gaining feedback from the stepper motor could be used instead of limit switches, is this not the case?
This is not the case, you can not obtain any feedback from the motor.
A normal DC motor will show a rise in current when it stalls and this can be used as a limit detector but this is not the case with a stepping motor because the maximum current it draws is when it is stopped, so you can't tell anything from the current draw from the motor. Still their is no way you get the current drawn from a motor it has to be done with external circuitry anyway.
