I have a working project which was done in PDS and would like now to convert it over to Arduino instead as this is all I use now and been a long time since I used basic.
But there is some bit's that I'm struggling with and tried many ways to convert it over.
Example Dim TEMP0 = 0 in basic and would be byte TEMP0 = 0; and this would be Dim DMM_ARRAY[14] As Byte in basic changed to byte DMM_ARRAY[14];
Not sure how I can achieve this from basic to Arduino
SerIn PORTC.7 , T2400 , [Str DMM_ARRAY\14] 'get the 14 bytes
Basic Str is a string arrary
Would this work Arduino code serial part only to start
byte buffer1[14]; ' store the data
int cnt = 0 ;
//void process_sample(void);
Serial.begin(2400);
Serial.println("START");
if ((cnt <14) && Serial.available()) buffer1[cnt++] = Serial.read(); ' get the serial data
This is another part I'm struggling with if I can convert this part I think the rest will be the same for LOOP2,3,4 as I'm not sure how to create a look downtable in Arduino
'BYTES 1&2 FOR THE FIRST DIGIT AND PRINTS THE NEGATIVE SIGN
For LOOP1 = 1 To 7 Step 2
TEMP1 = (DMM_ARRAY[1] <<4) | (DMM_ARRAY[2] &$0F)
If TEMP1.7 = 1 Then
Print At 2,1,"-"
'Print $FE, $C0, "-" 'PRINT THE DECIMAL POINT
Clear TEMP1.7 ' CLEAR THE MSB.
Else Print At 2,1," "'Print $FE, $C0, " " 'PRINT BLANK SAPCE IF CORRECT
EndIf
TEMP1 = LookDown TEMP1,[$7D,$05,$5B,$1F,$27,$3E,$7E,$15,$7F,$3F,$00,$68]' change to []={ 0x7D, 0x05, 0x5B, 0x1F, 0x27, 0x3E, 0x7E, 0x15, 0x7F, 0x3F, 0 }; for Arduino
Next LOOP1
The case select and printing to the LCD I should be able to work out, Here is the full basic code
Device = 16F883
'Config1 FOSC_xt, WDTE_OFF, PWRTE_OFF, MCLRE_ON, BOREN_OFF, BORV_20, DEBUG_OFF, CCP2MX_RC1, CP_OFF
'Config2 FCMEN_OFF, IESO_OFF, BORSEN_OFF
Config1 FOSC_HS, WDTE_OFF, PWRTE_OFF, MCLRE_ON, CP_OFF, CPD_OFF, BOREN_OFF, IESO_ON, FCMEN_OFF, LVP_OFF, DEBUG_OFF
Config2 BOR4V_BOR40V, WRT_OFF
;**** End of Fuse Configurator Settings ****
Declare LCD_DTPin = PORTC.0
Declare LCD_RSPin = PORTC.4
Declare LCD_ENPin = PORTC.5
Declare LCD_Interface = 4
Declare LCD_Lines = 2
Declare LCD_Type = 0
Declare LCD_CommandUs = 2000
Declare LCD_DataUs = 50 ' CURRENT CHOSEN DEVICE
All_Digital = true
Xtal = 4
Dim TEMP0 As Byte=0
Dim TEMP1 As Byte = 0
Dim TEMP2 As Byte = 0
Dim TEMP3 As Byte = 0
Dim TEMP4 As Byte = 0
Dim TEMP5 As Byte = 0
Dim TEMP6 As Byte = 0
Dim TEMP9 As Byte =0
Dim TEMP10 As Byte =0
Dim TEMP11 As Byte =0
Dim TEMP12 As Byte =0
Dim TEMP14 As Byte =0
Dim LOOP1 As Byte = 0
Dim LOOP2 As Byte = 0
Dim LOOP3 As Byte = 0
Dim LOOP4 As Byte = 0
Dim LOOP5 As Byte = 0
Dim LOOP As Byte = 0
Dim PRINT_SIGN As Byte =0
Dim PRINT_SIGN1 As Byte =0
Dim TEMP_STORED As Byte = 0
Dim STORED1 As Bit = 0
Dim STORED2 As Bit =0
Dim STORED3 As Bit =0
Dim STORED4 As Bit =0
Dim F_SELECT As Byte =0
Cls
DelayMS 100
MAIN:
If TEMP1.7 = 1 Then
Print At 2,1,"-"
EndIf
Next LOOP1
'BYTES 3&4 FOR THE SECOND DIGIT
For LOOP2 = 1 To 7 Step 2
TEMP2 = (DMM_ARRAY[3] <<4) | (DMM_ARRAY[4] &$0F)
STORED1 = TEMP2.7
Clear TEMP2.7 ' CLEAR THE MSB.
TEMP2 = LookDown TEMP2,[$7D,$05,$5B,$1F,$27,$3E,$7E,$15,$7F,$3F,$00,$68]
Next LOOP2
'BYTES 5&6 FOR THE THIRD DIGIT
For LOOP3 = 1 To 7 Step 2
TEMP3 = (DMM_ARRAY[5] <<4) | (DMM_ARRAY[6] &$0F)
STORED2 = TEMP3.7
Clear TEMP3.7 ' CLEAR THE MSB.
TEMP3 = LookDown TEMP3,[$7D,$05,$5B,$1F,$27,$3E,$7E,$15,$7F,$3F,$00,$68]
Next LOOP3
'BYTES 7&8 FOR THE FORTH DIGIT
For LOOP4 = 1 To 7 Step 2
TEMP4 = (DMM_ARRAY[7] <<4) | (DMM_ARRAY[8] &$0F)
STORED3 = TEMP4.7
Clear TEMP4.7 ' CLEAR THE MSB.
TEMP4 = LookDown TEMP4,[$7D,$05,$5B,$1F,$27,$3E,$7E,$15,$7F,$3F,$00,$68]
Next LOOP4
'SELECT THE SCREEN FOR PRINTING
If STORED1 = 1 And STORED2 = 0 And STORED3 = 0 And STORED4 = 0 Then F_SELECT = 1
If STORED1 = 0 And STORED2 = 1 And STORED3 = 0 And STORED4 = 0 Then F_SELECT = 2
If STORED1 = 0 And STORED2 = 0 And STORED3 = 1 And STORED4 = 0 Then F_SELECT = 3
If STORED1 = 0 And STORED2 = 0 And STORED3 = 0 And STORED4 = 0 Then F_SELECT = 4
If TEMP1 = 10 Then F_SELECT = 5
Select F_SELECT
Case 1
Print At 2,2,Dec1 TEMP1,".",Dec1 TEMP2,Dec1 TEMP3,Dec TEMP4," "
Case 2
Print At 2,2,Dec1 TEMP1,Dec1 TEMP2,".",Dec1 TEMP3,Dec TEMP4," "
Case 3
Print At 2,2,Dec1 TEMP1,Dec1 TEMP2,Dec1 TEMP3,".",Dec TEMP4," "
Case 4
Print At 2,2,Dec1 TEMP1,Dec1 TEMP2,Dec1 TEMP3,Dec TEMP4," "
Case 5
Print At 2,2," O.L "
End Select
If TEMP0.3 = 1 Then
Print At 1,7,"AC "
Else Print At 1,7,"DC "
EndIf
TEMP0 = DMM_ARRAY[0] & $0F
TEMP9 = DMM_ARRAY[9] & $0F
TEMP10 = DMM_ARRAY[10] & $0F
TEMP11 = DMM_ARRAY[11] & $0F
TEMP12 = DMM_ARRAY[12] & $0F
TEMP14 = DMM_ARRAY[13] & $0F
Print At 1,9,#TEMP14.3,#TEMP14.2,#TEMP14.2,#TEMP14.0
DelayMS 20
If TEMP10.3 = 1 And TEMP12.2 = 1 Then PRINT_SIGN = 0 'PRINT THE mV SIGN
If TEMP10.3 =0 And TEMP12.2 = 1 Then PRINT_SIGN = 1 'PRINT THE V SIGN
If TEMP11.2 =1 And TEMP11.1 =0 Then PRINT_SIGN = 2 'PRINT R SING FOR OHMS
If TEMP9.1 = 1 And TEMP11.2=1 Then PRINT_SIGN = 3 'PRINT K SING FOR OHMS
If TEMP10.1 =1 And TEMP11.2 = 1 Then PRINT_SIGN = 4 'PRINT THE M MEG OHMS
If TEMP9.0 = 1 And TEMP12.2= 1 Then PRINT_SIGN = 5 'DIODE
If TEMP10.0 =1 And TEMP11.2 = 1 Then PRINT_SIGN = 6 'BLLEP
If TEMP9.2 =1 And TEMP11.3= 1 Then PRINT_SIGN = 7 'nF CAP
If TEMP9.3 =1 And TEMP11.3=1 Then PRINT_SIGN = 8 'uF CAP
If TEMP9.1 = 0 And TEMP12.1 = 1 Then PRINT_SIGN = 9 ' HZ
If TEMP9.1 = 1 And TEMP12.1 = 1 Then PRINT_SIGN = 10 'k HZ
If TEMP10.1 = 1 And TEMP12.1 = 1 Then PRINT_SIGN = 11 ' mHZ
If TEMP10.2 = 1 And TEMP10.1 = 0 Then PRINT_SIGN = 12 'DUTY %
If TEMP9.3=0 And TEMP10.3 = 0 And TEMP11.3=0 And TEMP14.0 = 1 Then PRINT_SIGN = 13 'TEMP
If TEMP9.3 =1 And TEMP10.3 = 0 And TEMP11.3 =0 And TEMP12.3 = 1 Then PRINT_SIGN = 14 'u AMPS
If TEMP9.3=0 And TEMP10.3 = 1 And TEMP11.3=0 And TEMP12.3 = 1 Then PRINT_SIGN = 15 'm AMPS
If TEMP9.3=0 And TEMP10.3 = 0 And TEMP11.2=0 And TEMP12.3=1 Then PRINT_SIGN = 16 'A AMPS
Select PRINT_SIGN
Case 0
Print At 1,1,"VOLTS"
Print At 2,7,"mV"
Case 1
Print At 2,7," V"
Case 2
Print At 1,1," OHMS "
Print At 2,7," R"
Case 3
Print At 2,7," K"
Case 4
Print At 2,7," M"
Case 5
Print At 1,1," DIODE "
Print At 2,7," V"
Case 6
Print At 1,1," BLEEP "
Print At 2,7,"CM"
Case 7
Print At 1,1," CAP "
Print At 2,7,"nF"
Case 8
Print At 2,7,"uF"
Case 9
Print At 1,1," FREQ "
Print At 2,7,"HZ"
Case 10
Print At 2,7," k"
Case 11
Print 2,7," M"
Case 12
Print At 1,1," DUTY "
Print At 2,7," %"
Case 13
Print At 1,1," TEMP "
Print At 2,7," C"
Case 14
Print At 1,1," AMPS "
Print At 2,7,"uA"
Case 15
Print At 2,7,"mA"
Case 16
Print At 2,7," A"
End Select
GoTo MAIN
any guidance would be grateful
Thanks
Steve
