UTFT and Fonts help
Ok so I have another error being thrown up due to a different font im trying to use. I have arial_bold.c in my sketch folder and am receiving the following error. Arduino: 1.6.1 (Windows 7), Board: “Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)”
 C:\Program Files (x86)\Arduino\libraries\UTFT\arial_bold.c:9:9: error: variable 'arial_bold' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 uint8_t arial_bold[3044] PROGMEM={ [code]
here is the bit of my code im using for a variable [code]//*******Included Libraries*******//
#include <UTouch.h>
#include <avr/pgmspace.h>
#include <UTFT.h>
#include <tinyFAT.h>
#include <UTFT_tinyFAT.h>
#include <EEPROM.h>
#include <RTClib.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//********    Declare Touch/LCD/RTC    **********
UTFT  myGLCD(ITDB50, 38, 39, 40, 41);   //sets LCD pins - change to your screen pin-out and aspect
UTouch  myTouch( 6, 5, 4, 3, 2);        //sets touch pins - change to your set up (default is usually 6,5,4,3,2)
UTFT_tinyFAT myFiles(&myGLCD);
RTC_DS1307 RTC;
//********   Call Fonts    **********
extern uint8_t arial_bold[];
extern uint8_t Sinclair_S[];
extern uint8_t SevenSegmentFull[];[code]
any help to make this work will be appreciated thank you.
What does the font file look like? If it says prog_char, change it to const char
const char gives me
Arduino: 1.6.1 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
AquaPorn.ino:47:12: error: uninitialized const 'arial_bold' [-fpermissive]
AquaPorn.ino:47:23: error: storage size of 'arial_bold' isn't known
Error compiling.
[code]
not sure what you mean by the font type, this is the .c file
arial_bold.c (15.8 KB)
It should look like this.
const char arial_bold[3044] PROGMEM={
not uint8_t
ok, I got that changed now it throws up more errors.
#include <UTouch.h>
#include <UTFT.h>
#include <EEPROM.h>
#include <RTClib.h>
#include <Wire.h>
RTC_DS1307 RTC;
void Print_Change_Sunrise12() {                        //12 hour schedule
  if (ledevents_screen == true);
  if (SunTwelve == true) {
    myGLCD.setFont(arial_bold);
    myGLCD.setColor(0, 255, 255);
    if ((RiseHour <= 11) && (RiseHour >= 10)) {
      myGLCD.setBackColor(0, 0, 0);
      myGLCD.printNumI(RiseHour, 21, 76);
    if ((RiseHour <= 9) && (RiseHour >= 1)) {
      myGLCD.printNumI(RiseHour, 32, 76);
    if (RiseMin == 0) {
      myGLCD.print ("0" , 70, 76);
      myGLCD.printNumI(RiseMin, 85, 76);
    if ((RiseMin >= 10) && (RiseMin <= 59)) {
      myGLCD.printNumI(RiseMin, 69, 76);
    myGLCD.setColor(127, 127, 127);
    myGLCD.setBackColor(255, 0, 0);
    myGLCD.printNumI(RiseHour + 12, 20, 141);
    myGLCD.printNumI(RiseMin + 14, 68, 141);
    if (RiseMin == 0) {
void Print_Change_Sunrise8() {                        //8 hour schedule
  if (SunEight == true) {
    if ((RiseHour <= 15) && (RiseHour >= 10)) {
    if (RiseMin == 0) {
    myGLCD.printNumI(RiseHour + 8, 20, 141);
    if (RiseMin == 0) {
error...
AquaPorn.ino:47:37: error: expected primary-expression before ';' token
AquaPorn.ino: In function 'void Print_Change_Sunrise12()':
AquaPorn.ino:582:30: error: invalid conversion from '<type error>' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
In file included from AquaPorn.ino:30:0:
C:\Program Files (x86)\Arduino\libraries\UTFT/UTFT.h:219:8: error:   initializing argument 1 of 'void UTFT::setFont(uint8_t*)' [-fpermissive]
   void setFont(uint8_t* font);
:roll_eyes: No, this needs to be changed in the arial bold font file, not the sketch.
Then in the sketch you need to add
Done and Done, thanks for the help it works perfect now.
Your welcome.
