I just got my LCD. Tested the example files that came with it. Then edited the UTFT.h library to try some stuff. Copied back the original UTFT.h and now it won't compile.
The last upload on my Arduino is still working.
un and re-installed Arduino program. Still won't compile. Also tried another UTFT backup.
These were all working. Even worked when i was editing the UTFT Library. Errors started when I reverted to the un-edited UTFT file
Here's the first error
In file included from UTFT_Demo_480x320.ino:13:
C:\Program Files (x86)\Arduino\libraries\UTFT/UTFT.h:214: error: expected ';' before 'void'
UTFT_Demo_480x320.ino: In function 'void loop()':
UTFT_Demo_480x320:54: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:56: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:65: error: 'class UTFT' has no member named 'drawRect'
UTFT_Demo_480x320:102: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:132: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:155: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:161: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:190: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:219: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:246: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:261: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:271: error: 'class UTFT' has no member named 'drawRect'
UTFT_Demo_480x320:277: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:287: error: 'class UTFT' has no member named 'drawRoundRect'
UTFT_Demo_480x320:293: error: 'class UTFT' has no member named 'fillRect'
UTFT_Demo_480x320:308: error: 'class UTFT' has no member named 'fillRect'
Added the ";" to remove error (eventhough it compiled before) and got this
C:\Program Files (x86)\Arduino\libraries\UTFT\UTFT.cpp:465: error: prototype for 'void UTFT::drawRect(int, int, int, int)' does not match any in class 'UTFT'
C:\Program Files (x86)\Arduino\libraries\UTFT\/UTFT.h:213: error: candidate is: void UTFT::drawRect(uint16_t, uint16_t, uint16_t, uint16_t, float, float, uint16_t)
C:\Program Files (x86)\Arduino\libraries\UTFT\UTFT.cpp:482: error: no 'void UTFT::drawRoundRect(int, int, int, int)' member function declared in class 'UTFT'
