UTFT.h Help
Howdy, First off I am new to Arduino and still learning, Sorry if this is a silly question :slight_smile:
ok I have a tft display and I am using the UTFT.H Library. I can display text by using
myGLCD.print("www.arduinoprojectshq.com", CENTER, 227);
But I am trying to work out how to display a variable, I know it is probably easy but any help would be great.
James
Search UTFT documentation, there is one command like printNum( or similar to do that.
Cool thanks for that .. I found the Doco, I got it working.
int num = 3000;
myGLCD.printNumI(num, 10, 20);
Next Question :slight_smile:
Lets Say I have a ODB2 Shield connected to my car and everything setup, All i need to do now is display the RPM value in real time, For testing purposes would this be the best way of doing so ?
if (obd.ReadSensor(PID_RPM, rpm_value)) {
myGLCD.printNumI(rpm_value, 10, 20);
James
Yup. But only update the value if value changed. Also clear the zone, for example if you write "10" then "5" you need to append a " " space to clear the old number
Great thanks for that, I have found myGLCD.clrScr(); but that clears the screen. do you know how i can clear the zone ?
James
print " "
