UTFT library, error ´class UTFT´has no member called ´fillScr´
I am using the attached code from Henning Karlsen´s website. I pasted the unzipped downloaded UTFT directory in
my documents/Arduino/libraries as I have done for all the libraries I successfully installed. But I get this errors when I verify it:
UTFT_Bitmap.ino: In function ‘void loop()’:
UTFT_Bitmap:45: error: ‘class UTFT’ has no member named ‘fillScr’
UTFT_Bitmap:46: error: ‘class UTFT’ has no member named ‘setColor’
UTFT_Bitmap:47: error: ‘class UTFT’ has no member named ‘print’
UTFT_Bitmap:50: error: ‘class UTFT’ has no member named ‘drawBitmap’
UTFT_Bitmap:54: error: ‘class UTFT’ has no member named ‘fillScr’
UTFT_Bitmap:55: error: ‘class UTFT’ has no member named ‘setColor’
UTFT_Bitmap:56: error: ‘class UTFT’ has no member named ‘print’
UTFT_Bitmap:61: error: ‘class UTFT’ has no member named ‘drawBitmap’
UTFT_Bitmap:66: error: ‘class UTFT’ has no member named ‘drawBitmap’
UTFT_Bitmap.ino (1.84 KB)
What Arduino are you using?
Which example are you using:
File->Examples->UTFT->Arduino (ARM) + Teensy->UTFT_Bitmap
File->Examples->UTFT->Arduino (AVR)->UTFT_Bitmap
File->Examples->UTFT->chipkit->UTFT_Bitmap
The Arduino (AVR)->UTFT_Bitmap compiles fine for an Arduino MEGA. On an Arduino UNO the compile completes but the resulting binary is too big for the ATmega328P.
