UTFT_Bitmap sketch compiles for Mega2560 but not for DUE
I am starting LCD programming. I have a HX8357B LCD but it is not connected now.
Bitmap demo does not even compile. This is the long error message
Arduino: 1.6.7 (Windows 7), Board: "Arduino Due (Programming Port)"
Build options changed, rebuilding all
In file included from C:\Users\LM7\Documents\Arduino\libraries\UTFT/UTFT.h:180:0,
                 from C:\Users\LM7\Documents\Arduino\libraries\UTFT\examples\Arduino (AVR)\UTFT_Bitmap\UTFT_Bitmap.ino:13:
C:\Users\LM7\Documents\Arduino\libraries\UTFT/hardware/arm/HW_ARM_defines.h:30:0: warning: "pgm_read_word" redefined [enabled by default]
 #define pgm_read_word(data) *data
In file included from C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.6\cores\arduino/Arduino.h:31:0,
                 from sketch\UTFT_Bitmap.ino.cpp:1:
C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.6\cores\arduino/avr/pgmspace.h:57:0: note: this is the location of the previous definition
 #define pgm_read_word(addr) (*(const unsigned short *)(addr))
C:\Users\LM7\Documents\Arduino\libraries\UTFT/hardware/arm/HW_ARM_defines.h:31:0: warning: "pgm_read_byte" redefined [enabled by default]
 #define pgm_read_byte(data) *data
C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.6\cores\arduino/avr/pgmspace.h:56:0: note: this is the location of the previous definition
 #define pgm_read_byte(addr) (*(const unsigned char *)(addr))
C:\Users\LM7\Documents\Arduino\libraries\UTFT\examples\Arduino (AVR)\UTFT_Bitmap\UTFT_Bitmap.ino: In function 'void loop()':
C:\Users\LM7\Documents\Arduino\libraries\UTFT\examples\Arduino (AVR)\UTFT_Bitmap\UTFT_Bitmap.ino:48:71: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   myGLCD.print(" *** A 10 by 7 grid of a 32x32 icon *** ", CENTER, 228);
UTFT_Bitmap:51: error: no matching function for call to 'UTFT::drawBitmap(int, int, int, int, unsigned int [1024])'
       myGLCD.drawBitmap (x*32, y*32, 32, 32, info);
C:\Users\LM7\Documents\Arduino\libraries\UTFT\examples\Arduino (AVR)\UTFT_Bitmap\UTFT_Bitmap.ino:51:50: note: candidates are:
In file included from C:\Users\LM7\Documents\Arduino\libraries\UTFT\examples\Arduino (AVR)\UTFT_Bitmap\UTFT_Bitmap.ino:13:0:
C:\Users\LM7\Documents\Arduino\libraries\UTFT/UTFT.h:223:8: note: void UTFT::drawBitmap(int, int, int, int, short unsigned int*, int)
   void drawBitmap(int x, int y, int sx, int sy, bitmapdatatype data, int scale=1);
C:\Users\LM7\Documents\Arduino\libraries\UTFT/UTFT.h:223:8: note:   no known conversion for argument 5 from 'unsigned int [1024]' to 'short unsigned int*'
C:\Users\LM7\Documents\Arduino\libraries\UTFT/UTFT.h:224:8: note: void UTFT::drawBitmap(int, int, int, int, short unsigned int*, int, int, int)
   void drawBitmap(int x, int y, int sx, int sy, bitmapdatatype data, int deg, int rox, int roy);
C:\Users\LM7\Documents\Arduino\libraries\UTFT/UTFT.h:224:8: note:   candidate expects 8 arguments, 5 provided
C:\Users\LM7\Documents\Arduino\libraries\UTFT\examples\Arduino (AVR)\UTFT_Bitmap\UTFT_Bitmap.ino:57:71: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   myGLCD.print("   Two different icons in scale 1 to 4  ", CENTER, 228);
UTFT_Bitmap:62: error: no matching function for call to 'UTFT::drawBitmap(int&, int, int, int, unsigned int [1024], int)'
     myGLCD.drawBitmap (x, 0, 32, 32, tux, s+1);
C:\Users\LM7\Documents\Arduino\libraries\UTFT\examples\Arduino (AVR)\UTFT_Bitmap\UTFT_Bitmap.ino:62:46: note: candidates are:
C:\Users\LM7\Documents\Arduino\libraries\UTFT/UTFT.h:224:8: note:   candidate expects 8 arguments, 6 provided
UTFT_Bitmap:67: error: no matching function for call to 'UTFT::drawBitmap(int&, int, int, int, unsigned int [1024], int&)'
     myGLCD.drawBitmap (x, 224-(s*32), 32, 32, icon, s);
C:\Users\LM7\Documents\Arduino\libraries\UTFT\examples\Arduino (AVR)\UTFT_Bitmap\UTFT_Bitmap.ino:67:54: note: candidates are:
exit status 1
  enabled in File > Preferences.
You have to load the example in the ARM folder, not the AVR (DUE is ARM, all the others are AVR)
Thank you. That was it.
When I quickly looked at examples, I did not even notice the difference between AVR and ARM.
