uti interfacing
i recentely bought uti 03,sensor...
plz..verify excitation has + and - peaks of square wave voltage..
?? post datsheet
Thank u for ur reply,
Uti 03,a,b,c,d ,can accept -Ve voltges?
DATA SHEET IS http://smartec-sensors.com/assets/files/pdf/sensors/SMTUTIN.PDF...
I read:
"Input voltage ref. to Vss -0.3 V to Vdd +0.3 V "
In uti03,excitation signal generated by E and F,so i didn't used that one,
i externally connected excitation source to resistor bridge mode,but uti03 not responce properly?
plz..clarify how to use external excitation source to uti?
regards,
In UTI03,MODE11,
can use the external excitation voltage to measure resistances?
plz,clarify it will works only internal excitation volatge source?
regards
I guess its ment to use the internal excitation voltage, but I cant find mention that external power isn't possible.
use common GND? ..and input voltage should be within .4V - 4.4V (if 5V to chip Vcc)
Then if the bridge has almost evenly distributed resistance, the exitation voltage must be no more than ca. 8.5V
The chip then reads the differential voltage
