I'm using Arduino IDE 1.8.1 on windows 10 and I'm getting something very strange.
The problem only happens if using util/delay.h and the _delay_ms(), _delay_us() functions.
Removing the include and F_CPU #define and using delay() and delayMicroseconds() solved the problem.
But, as this code will (probably) evolve to an ISR routine I might need to use util/delay.h, I have used it several times, but this is the first time I use _delay_us(), is it broken ???
The code bellow fails to compile with the following errors
C:\Users\Antonio\Documents\Arduino\nano-waves-01\nano-waves-01.ino:1:0: warning: "F_CPU" redefined
#define F_CPU 16000000UL
<command-line>:0:0: note: this is the location of the previous definition
c:\users\antonio\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\util\delay.h: In function 'triang.constprop':
c:\users\antonio\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\util\delay.h:276:40: error: __builtin_avr_delay_cycles expects a compile time integer constant
__builtin_avr_delay_cycles(__ticks_dc);
lto-wrapper: C:\Users\Antonio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc returned 1 exit status
c:/users/antonio/appdata/local/arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Nano.
However, this only happens if I have more than one call to function triang() anywhere in the program, being it inside loop() or setup() and ONLY if the call is made with different parameters.
triang(432,500,128);
compiles ok
triang(432,499,128);
does NOT compile.
At first I thought that it happens if I have more than one call to triang() but no, it only happens if any of the parameters is different.
#include <util/delay.h>
#define pin 5
void triang(float, int, int);
pinMode(pin, OUTPUT);
int f;
for(f=0;f<10;f++)
Serial.print("["); Serial.print(f); Serial.print("]");
triang(432, 500, 256);
triang(432, 500, 128);
tone(pin,432);
_delay_ms(500);
noTone(pin);
_delay_ms(1000);
while(1);
void triang(float freq, int dur, int stp)
int f;
double T;
unsigned long int t_us;
unsigned long int then;
char buf[64];
then=micros()+(dur*1000UL);
T=1/freq;
t_us=((T/(stp*2))*1000000UL);
dtostrf(T, 16, 8, buf);
Serial.print("T=");
Serial.println(buf);
while(micros()<then)
for(f=0;f<256;f+=(256/stp))
analogWrite(pin, f);
_delay_us(t_us);
for(f=255;f>0;f-=(256/stp))
_delay_us(t_us);
analogWrite(pin,0);
