Utiliser internet !
Je fait un projet d'une petite voiture commandé à distance , le projet est fini mais j'aimerai ajouter l'internet en utilisant Processing.
J'ai essayer ce code (exemple) pour communiquer entre un serveur et un client qui sont les deux dans mon ordinateur , le serveur utilise mon IP et le client se connecte a lui mais ca ne marche pas je ne comprend pas pourquoi .
Voici les deux codes :
Coté Serveur :
 * Shared Drawing Canvas (Server)
 * by Alexander R. Galloway.
 * A server that shares a drawing canvas between two computers.
 * In order to open a socket connection, a server must select a
 * port on which to listen for incoming clients and through which
 * to communicate. Once the socket is established, a client may
 * connect to the server and send or receive commands and data.
 * Get this program running and then start the Shared Drawing
 * Canvas (Client) program so see how they interact.
import processing.net.*;
Server s;
Client c;
String input;
int data[];
  size(450, 255);
  background(204);
  stroke(0);
  frameRate(5); // Slow it down a little
  s = new Server(this, 12345); // Start a simple server on a port
void draw()
  if (mousePressed == true) {
    // Draw our line
    stroke(255);
    line(pmouseX, pmouseY, mouseX, mouseY);
    // Send mouse coords to other person
    s.write(pmouseX + " " + pmouseY + " " + mouseX + " " + mouseY + "\n");
  // Receive data from client
  c = s.available();
  if (c != null) {
    input = c.readString();
    input = input.substring(0, input.indexOf("\n")); // Only up to the newline
    data = int(split(input, ' ')); // Split values into an array
    // Draw line using received coords
    stroke(0);
    line(data[0], data[1], data[2], data[3]);
Coté Client :
 * Shared Drawing Canvas (Client)
 * The Processing Client class is instantiated by specifying a remote
 * address and port number to which the socket connection should be made.
 * Once the connection is made, the client may read (or write) data to the server.
 * Before running this program, start the Shared Drawing Canvas (Server) program.
Client c;
String input;
int data[];
  size(450, 255);
  background(204);
  stroke(0);
  // Connect to the server's IP address and port
  c = new Client(this, "ici mon adresse IP", 12345); // Replace with your server's IP and port
void draw()
    // Draw our line
    stroke(255);
    c.write(pmouseX + " " + pmouseY + " " + mouseX + " " + mouseY + "\n");
  // Receive data from server
  if (c.available() > 0) {
    stroke(0);
bonjour,
tu as bien suivi ceci?
On lance d'abord le programme serveur (si on lance le client en 1er, on a un message d'erreur car le client ne trouve pas le serveur...)
puis on lance le programme client (qui se connecte au serveur..)
Biensur que ci ! Doit-je créé un serveur ou c'est normal qu'ont choisi son adresse IP ?
Je vais essayer de créé mon propre serveur avec Apache , peu etre que ca marchera . :grin:
