Hi All
I am using the code below to read my magnetic door and PIR sensors and publish to my MQTT server.
The code is working well but I have the need to add more GPIO pins using a MCP23017 to the project.
This is where I am getting confused as the pin numbers in the original code refers to the NodeMCU pins. How do I go about using the mcp pins in this project as well?
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <Wire.h>
#include "Adafruit_MCP23017.h"
#define WLAN_SSID "myssid"
#define WLAN_PASS "****"
WiFiClient client;
PubSubClient mqtt(client, "192.168.0.76", 1883);
#define SENSOR_COUNT 6
#define DEVICE_NAME "Alarm-Node2"
byte sensorPins[SENSOR_COUNT] = {0, 2, 14, 12, 13, 10}; // The NODEMCU pins to which the sensors are connected.
boolean sensorStates[SENSOR_COUNT] = {1, 1, 1, 1, 1, 1};
String deviceName = DEVICE_NAME;
String sensorNames[SENSOR_COUNT] = {"D3","D4","D5","D6","D7","D12"}; //
Adafruit_MCP23017 mcp;
mcp.begin(); // use default address 0
//mcp.begin(); // use default address 0
// the the pinmode for all used pins to INPUT_PULLUP
for (byte i = 0; i < SENSOR_COUNT; i++) {
byte pin = sensorPins[i];
pinMode(pin, INPUT);
mcp.pinMode(0, INPUT);
mcp.pinMode(1, INPUT);
mcp.pinMode(2, INPUT);
mcp.pinMode(3, INPUT);
mcp.pinMode(4, INPUT);
mcp.pinMode(5, INPUT);
mcp.pinMode(6, INPUT);
mcp.pinMode(7, INPUT);
mcp.pinMode(8, INPUT);
mcp.pinMode(9, INPUT);
mcp.pinMode(10, INPUT);
mcp.pinMode(11, INPUT);
mcp.pinMode(12, INPUT);
mcp.pinMode(13, INPUT);
mcp.pinMode(14, INPUT);
mcp.pinMode(15, INPUT);
// Initiate the serial connection for debugging.
delay(10);
Serial.println("Starting ...");
// Check if the Wifi is connected, if not, call the WiFi_connect() method.
if (WiFi.status() != WL_CONNECTED) {
WiFi_connect();
// Check if there is a connection with the MQTT server, if not, call the MQTT_connect() method.
if (!mqtt.connected()) {
Serial.println("MQTT Disconnected!");
MQTT_connect();
// Call the loop method, to periodically ping the server to keep the connection alive.
mqtt.loop();
// Loop thru all the sensors defined at the start.
// Create some helper variables.
boolean pinState = digitalRead(pin);
boolean lastPinState = sensorStates[i];
String sensorName = sensorNames[i];
// Check if the state for the current pin has changed.
if (pinState != lastPinState) {
// Define a string with the topic to which we want to post the new state to ...
// and convert it into a char * array which we need for the pubsubclient.
String feedNameString = String("/device/" + deviceName + "/sensor/" + sensorName);
char topic[feedNameString.length() + 1];
feedNameString.toCharArray(topic, feedNameString.length() + 1);
// Output the new state to the serial for debugging.
Serial.print("New state for sensor ");
Serial.print(topic);
Serial.print(": ");
Serial.print(pinState);
// Publish the new state to the MQTT server.
// The message is sent as a retained message to always
// have the last state available on the broker.
// The QoS is set to 1, to make sure the delivery
// of the mseeage to the broker is guaranteed.
if (mqtt.publish(MQTT::Publish(topic, pinState ? "1" : "0").set_retain().set_qos(1).set_dup())) {
Serial.println(F(" ... Published!"));
Serial.println(F(" ... MQTT PUBLISH FAILED!"));
// Store the new pinstate in the pinStates array.
sensorStates[i] = pinState;
// Wait 50 miliseconds before we repeat the runloop.
delay(50);
void WiFi_connect() {
// Print some debuggin info to the serial terminal.
Serial.println(); Serial.println();
Serial.print("Connecting to ");
Serial.print(WLAN_SSID);
Serial.print(" ");
// Connect to the WiFi netwerk using the previously defined SSID and Password.
WiFi.begin(WLAN_SSID, WLAN_PASS);
// If there is no connection. Wait half a second before checking again.
Serial.print(".");
// After the connection is established, print the IP-adres to the serial terminal for debugging.
Serial.print("WiFi connected! - ");
Serial.print("IP address: ");
void MQTT_connect() {
// Define a string with the topic to which we want to post the connection state of this device to ...
String feedNameString = String("/device/" + deviceName + "/connected");
// As long as there is no active MQTT connection ...
while (!mqtt.connected()) {
Serial.print("Attempting MQTT connection ... ");
// Try to connect to the MQTT broker.
// As the 'will' we set the topic and connection state to 0.
// This means that is if the connection is dropped,
// the broker will publish the connection state to the defined topic.
if (mqtt.connect(MQTT::Connect(DEVICE_NAME).set_will(topic, "0", 1, true))) {
Serial.println("Connected!");
// After the connection is established, publish a new connection state.
mqtt.publish(MQTT::Publish(topic, "1").set_retain().set_qos(1));
// Wait half a second before trying again.
Serial.println("Failed! - Try again in half a second.");
I am trying to use one of the library examples as an guide on how to build further onto the main code:
#include <Wire.h>
// Basic pin reading and pullup test for the MCP23017 I/O expander
// public domain!
// Connect pin #12 of the expander to Analog 5 (i2c clock)
// Connect pin #13 of the expander to Analog 4 (i2c data)
// Connect pins #15, 16 and 17 of the expander to ground (address selection)
// Connect pin #9 of the expander to 5V (power)
// Connect pin #10 of the expander to ground (common ground)
// Connect pin #18 through a ~10kohm resistor to 5V (reset pin, active low)
// Input #0 is on pin 21 so connect a button or switch from there to ground
mcp.pullUp(0, HIGH); // turn on a 100K pullup internally
pinMode(13, OUTPUT); // use the p13 LED as debugging
// The LED will 'echo' the button
digitalWrite(13, mcp.digitalRead(0));
I would greatly appreciate advice and assistance.
