I want to use the arduino keypad library @ Arduino Playground - Keypad Library as a property on a class "Keyblock". I am no unable to initialize it because it requires parameters for the constructor. However those parameters are not allowed because they are not static (as far as I am aware). Code is below...
Main.ino
#include "Debug.h"
#include "Keyblock.h"
Debug debug;
Keyblock keyblock;
void loop(){
keyblock.getKey();
void setup(){
debug.message("Setup Complete");
Keyblock.h
#ifndef KEYBLOCK_H
#define KEYBLOCK_H
#include <SPI.h>
#include <Keypad.h>
#include "Debug.h"
class Keyblock {
private:
static constexpr unsigned ROWS = 4;
static constexpr unsigned COLS = 3;
static constexpr char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
// put your pins in these arrays:
static constexpr byte keypadRowPins[ROWS] = { 9, 8, 7, 6 };
static constexpr byte keypadColPins[COLS] = { 12, 11, 10 };
Keypad keypad;
Debug debug;
public:
Keyblock(); // add a user-defined default constructor
void getKey();
#endif
Keyblock.cpp
Keyblock::Keyblock() : // member init-list between `:` and the body of the constructor
keypad(makeKeymap(keys), keypadRowPins, keypadColPins, ROWS, COLS),
debug(debug)
void Keyblock::getKey() {
char key = keypad.getKey();
debug.message(key);
Errors :
sketch\Keyblock.cpp: In constructor 'Keyblock::Keyblock()':
sketch\Keyblock.cpp:5:16: warning: invalid conversion from 'const byte* {aka const unsigned char*}' to 'byte* {aka unsigned char*}' [-fpermissive]
debug(debug)
In file included from sketch\Keyblock.h:5:0,
from sketch\Keyblock.cpp:1:
C:\Users\campo\Documents\Arduino\libraries\Keypad\src/Keypad.h:78:2: note: initializing argument 2 of 'Keypad::Keypad(char*, byte*, byte*, byte, byte)'
Keypad(char *userKeymap, byte *row, byte *col, byte numRows, byte numCols);
debug(debug)
C:\Users\campo\Documents\Arduino\libraries\Keypad\src/Keypad.h:78:2: note: initializing argument 3 of 'Keypad::Keypad(char*, byte*, byte*, byte, byte)'
sketch\Keyblock.cpp:3:1: warning: 'Keyblock::debug' is initialized with itself [-Winit-self]
C:\Users\campo\AppData\Local\Temp\ccxzZ5s3.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_Debug.cpp.o.2048':
<artificial>:(.text.startup+0x100): undefined reference to `Keyblock::keypadRowPins'
<artificial>:(.text.startup+0x102): undefined reference to `Keyblock::keypadRowPins'
<artificial>:(.text.startup+0x10c): undefined reference to `Keyblock::keypadColPins'
<artificial>:(.text.startup+0x10e): undefined reference to `Keyblock::keypadColPins'
<artificial>:(.text.startup+0x124): undefined reference to `Keyblock::keys'
<artificial>:(.text.startup+0x126): undefined reference to `Keyblock::keys'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
If change the properties to something like
unsigned int ROWS = 4;
unsigned int COLS = 3;
I get the following errors
Keyblock.h:13:38: error: invalid use of non-static data member 'Keyblock::COLS'
sketch\Keyblock.h:11:25: note: declared here
Keyblock.h:21:34: error: invalid use of non-static data member 'Keyblock::ROWS'
sketch\Keyblock.h:10:25: note: declared here
Keyblock.h:22:34: error: invalid use of non-static data member 'Keyblock::COLS'
I found this approach below compiles but it seems like a horrible design/mess. Maybe its the best way but I was hoping to find something that is cleaner.
#ifndef KEYBLOCK_H
#define KEYBLOCK_H
#include <SPI.h>
#include <Keypad.h>
#include "Debug.h"
class Keyblock {
private:
// const unsigned int ROWS;
// const unsigned int COLS;
int ROWS;
int COLS;
char keys[4][3];
byte keypadRowPins[4];
byte keypadColPins[3];
Keypad keypad;
Debug debug;
public:
Keyblock():
ROWS = 4;
COLS = 3;
char _keys[4][3] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
for(int i = 0; i < 4; i++){
for(int j = 0; j < 3; j++){
keys[i][j] = _keys[i][j];
char _keypadRowPins[4] = { 9, 8, 7, 6 };
char _keypadColPins[3] = { 12, 11, 10 };
keypadRowPins[i] = _keypadRowPins[i];
for(int i = 0; i < 3; i++){
keypadColPins[i] = _keypadColPins[i];
void getKey();
#endif
