I am trying to make a UV index meter. When the UV level is below 3, the LED (Neopixel) would be green. When the UV level in from 3 - 6, the LED would be yellow. When the UV level is between 6-8 the LED would be orange. When between 8 to 11 it should be red.
Problem: When I upload the program to the Arduino, the LED flashes between red and green at about a 10-second interval, no matter what the UV sensor is exposed to. Sorry for the very long code. I am certain half of it is useless because I'm a beginner.
This is a library for the Si1145 UV/IR/Visible Light Sensor
Designed specifically to work with the Si1145 sensor in the
adafruit shop
----> https://www.adafruit.com/products/1777
These sensors use I2C to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include "Adafruit_SI1145.h"
#ifdef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
Adafruit_SI1145 uv = Adafruit_SI1145();
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN 6 // On Trinket or Gemma, suggest changing this to 1
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 16 // Popular NeoPixel ring size
// When setting up the NeoPixel library, we tell it how many pixels,
// and which pin to use to send signals. Note that for older NeoPixel
// strips you might need to change the third parameter -- see the
// strandtest example for more information on possible values.
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
#define DELAYVAL 500 // Time (in milliseconds) to pause between pixels
Serial.println("Adafruit SI1145 test");
if (! uv.begin()) {
Serial.println("Didn't find Si1145");
while (1);
Serial.println("OK!");
Serial.println("===================");
Serial.print("Vis: "); Serial.println(uv.readVisible());
Serial.print("IR: "); Serial.println(uv.readIR());
// Uncomment if you have an IR LED attached to LED pin!
//Serial.print("Prox: "); Serial.println(uv.readProx());
float UVindex = uv.readUV();
// the index is multiplied by 100 so to get the
// integer index, divide by 100!
UVindex /= 100.0;
Serial.print("UV: "); Serial.println(UVindex);
delay(100);
// These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
// Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
#endif
// END of Trinket-specific code.
pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
if (UVindex < 3.0) //Green low
pixels.clear(); // Set all pixel colors to 'off'
// The first NeoPixel in a strand is #0, second is 1, all the way up
// to the count of pixels minus one.
for(int i=0; i<NUMPIXELS; i++) { // For each pixel...
// pixels.Color() takes RGB values, from 0,0,0 up to 255,255,255
// Here we're using a moderately bright green color:
pixels.setPixelColor(i, pixels.Color(0, 150, 0));
pixels.show(); // Send the updated pixel colors to the hardware.
delay(DELAYVAL); // Pause before next pass through loop
else if (UVindex >= 3 && UVindex <6) //Medium yellow
pixels.setPixelColor(i, pixels.Color(255,255,0));
else if (UVindex >= 6 && UVindex <8) //High orange
pixels.setPixelColor(i, pixels.Color(255, 165, 0));
else (UVindex >= 8 && UVindex <11); //Extreme red
pixels.setPixelColor(i, pixels.Color(255, 0, 0));
delay(100);
