V-USB NES to USB connection issue
Hello all I’m having trouble troubleshooting my project
I used the the following tutorial:
http://www.bidouille.org/elec/usbnesadapter
And uploaded the following code to a ATTiny45 using an Arduino as ISP
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <avr/wdt.h>
#include <avr/eeprom.h>
#include <usbdrv/usbdrv.h>
#include <stdlib.h>
#include <string.h>
#include "config.h"
#include "nes.h"
FUSES =
  .low = (FUSE_CKSEL1 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0), // Int osc HF PLL, slow rising power
  .high = (FUSE_SPIEN & FUSE_BODLEVEL1), // Enable serial programming, BOD 2.7V
  .extended = EFUSE_DEFAULT,
struct{
  union {
    uint8_t data;
    struct {
      uint8_t X:2;
      uint8_t Y:2;
      uint8_t B:1;
      uint8_t A:1;
      uint8_t SELECT:1;
      uint8_t START:1;
} reportBuffer;
usbMsgLen_t usbFunctionSetup(uchar data[8]) {
  usbRequest_t *req = (void *)data;
  return 0; // Nothing implemented
/* ------------------------ Oscillator Calibration ------------------------- */
/* Calibrate the RC oscillator to 8.25 MHz. The core clock of 16.5 MHz is
 * derived from the 66 MHz peripheral clock by dividing. Our timing reference
 * is the Start Of Frame signal (a single SE0 bit) available immediately after
 * a USB RESET. We first do a binary search for the OSCCAL value and then
 * optimize this value with a neighboorhod search.
 * This algorithm may also be used to calibrate the RC oscillator directly to
 * 12 MHz (no PLL involved, can therefore be used on almost ALL AVRs), but this
 * is wide outside the spec for the OSCCAL value and the required precision for
 * the 12 MHz clock! Use the RC oscillator calibrated to 12 MHz for
 * experimental purposes only!
static void calibrateOscillator(void)
uchar       step = 128;
uchar       trialValue = 0, optimumValue;
int         x, optimumDev, targetValue = (unsigned)(1499 * (double)F_CPU / 10.5e6 + 0.5);
    /* do a binary search: */
    do{
        OSCCAL = trialValue + step;
        x = usbMeasureFrameLength();    /* proportional to current real frequency */
        if(x < targetValue)             /* frequency still too low */
            trialValue += step;
        step >>= 1;
    }while(step > 0);
    /* We have a precision of +/- 1 for optimum OSCCAL here */
    /* now do a neighborhood search for optimum value */
    optimumValue = trialValue;
    optimumDev = x; /* this is certainly far away from optimum */
    for(OSCCAL = trialValue - 1; OSCCAL <= trialValue + 1; OSCCAL++){
        x = usbMeasureFrameLength() - targetValue;
        if(x < 0)
            x = -x;
        if(x < optimumDev){
            optimumDev = x;
            optimumValue = OSCCAL;
    OSCCAL = optimumValue;
Note: This calibration algorithm may try OSCCAL values of up to 192 even if
the optimum value is far below 192. It may therefore exceed the allowed clock
frequency of the CPU in low voltage designs!
You may replace this search algorithm with any other algorithm you like if
you have additional constraints such as a maximum CPU clock.
For version 5.x RC oscillators (those with a split range of 2x128 steps, e.g.
ATTiny25, ATTiny45, ATTiny85), it may be useful to search for the optimum in
both regions.
void hadUsbReset(void) {
  calibrateOscillator();
  eeprom_write_byte(0, OSCCAL);   /* store the calibrated value in EEPROM */
// Clock pulse width >= 500ns
#define STROBE_CLK() sbi(NES_PORT, CLK); \
                     _delay_us(1); \
                     cbi(NES_PORT, CLK); \
                     _delay_us(1);
int main(void) {
  uchar calibrationValue;
  while (!eeprom_is_ready());
  calibrationValue = eeprom_read_byte(0); /* calibration value from last time */
  if(calibrationValue != 0xff) {
    OSCCAL = calibrationValue;
  _delay_ms(10);
  ACSR |= (1<<ACD); // Disable analog comparator
  usbDeviceDisconnect();  /* enforce re-enumeration, do this while interrupts are disabled! */
  _delay_ms(500);
  usbDeviceConnect();
  wdt_enable(WDTO_1S);
  usbInit();
  sei();
  sbi(NES_DDR, CLK);
  cbi(NES_DDR, OUT);
  sbi(NES_DDR, LATCH);
  cbi(NES_PORT, CLK);
  cbi(NES_PORT, LATCH);
  for(;;) {
    wdt_reset();
    usbPoll();
    if(usbInterruptIsReady()){
      reportBuffer.data = 0x05; // Center pad, little endian
      sbi(NES_PORT, LATCH);
      _delay_us(1); // Latch pulse width >= 500ns
      _delay_us(1); // Propagation time <= 1000ns
      if(bit_is_clear(NES_PIN, OUT))
        reportBuffer.A = 1;
      STROBE_CLK();
        reportBuffer.B = 1;
      STROBE_CLK();
        reportBuffer.SELECT = 1;
      STROBE_CLK();
        reportBuffer.START = 1;
      STROBE_CLK();
        reportBuffer.Y--;
      STROBE_CLK();
        reportBuffer.Y++;
      STROBE_CLK();
        reportBuffer.X--;
      STROBE_CLK();
        reportBuffer.X++;
      /* called after every poll of the interrupt endpoint */
      usbSetInterrupt(&reportBuffer, sizeof(reportBuffer));
The problem is that when I plug my circuit into my pc it registers a USB device then it disconnects then connects, etc. It’s like it’s fluctuating. I’ve checked the ATTiny by uploading the blink sample and it works. Any help would be greatly appreciated. I’m not a super programmer and mostly a hobby electronics person.
Right, so after checking my circuit for the upteenth time I know it's correct. The following is the error log
main.c:36: error: expected '=', ',', ';', 'asm' or 'attribute' before 'usbFunctionSetup' main.c: In function 'calibrateOscillator': main.c:59: error: 'uchar' undeclared (first use in this function) main.c:59: error: (Each undeclared identifier is reported only once main.c:59: error: for each function it appears in.) main.c:59: error: expected ';' before 'step' main.c:60: error: expected ';' before 'trialValue' main.c:65: error: 'trialValue' undeclared (first use in this function) main.c:65: error: 'step' undeclared (first use in this function) main.c:73: error: 'optimumValue' undeclared (first use in this function) main.c: In function 'main': main.c:109: error: 'uchar' undeclared (first use in this function) main.c:109: error: expected ';' before 'calibrationValue' main.c:111: error: 'calibrationValue' undeclared (first use in this function)
From looking at other projects I see that undeclared variables will not prevent a successful load because they may be inputs not connected. My big questions, despite being completely inexperienced, is why the usbFunctionSetup is throwing an error. Any help would be greatly appreciated. This is the last hurdle for a birthday project for my brother.
