VAC8610F Wireless Voltage Ampere Is there a way to bring it to Voltage Meter's modusbus?
VAC8610F
Is there a way to bring it to Voltage Meter's modbus?
I was only given a short Hex Code.
1111
The contents of the document only show this way.
Communication Protocol:
Baud rate: 9600
Send data format 0xFA +(FCH value)
Beginning value 0xFA( hexadecimal)
The address bit (FCH value) is converted to the corresponding hexadecimal number if the FCH value is tested with the serial port assistant
If sent: 0xFA 0x40
Returns 27 data:
Data1= xFA0
Data2=FCH
DC current value: (Data3<<8|Data4)/1000
DC voltage value: Data5<<8|Data6
Cumulative energy value (WH):(Data7<<24| Data8||Data8<<16)/1000
Cumulative capacity value (AH):(Data11<<24| Data12||Data12<<16)/1000
Percentage of residual capacity: Data15/100;
Current direction: Data16(0:negative current ;1: positive current)
Charging relay working status: Data17
Discharge relay working status: Data18
Run cumulative time :(Data19<<24|Data20Data19<<Data19<<16|Data20Data19<<Data19<<Data21Data19<<Data19<<8)(seconds)
Temperature: Data23
Output status value: Data24
Timing start-stop value: Data25
Empty: Data26
Empty: Data27
Attention and maintenance
  1. can not exceed the instrument voltage and current range, otherwise it will damage the instrument.
  2. positive and negative electrodes can not be reversed, the reverse can not be measured correctly.
  3. operating temperature-10~50℃, storage temperature-20 and 70℃, and keep the instrument in a dry environment.
  4. do not try to disassemble this instrument, damage to the package will lead to warranty failure. There are no parts that can be repaired by the user. The maintenance can only be sent back to the factory through the designated maintenance network.
Do not move the instrument violently 5. the instrument works to avoid irreparable damage to the internal circuit.
