Vacuum pump as air compressor?
Would a vacuum pump with enough power to reduce the air pressure down to 0.5 bar (-50%) also be capable to increase air pressure up to 1.5 bar (+50%)?
Any help is appreciated.
IF it is a piston pump, then it might be possible. Are you able to make the plumbing connections?
Paul
I'm thinking about using this one:
Be sure to mount the motor to some type of heat sink if you intend to run it for very long.
Paul
I'll do that. Thanks for the help
