'Val' doesn't name the type, can you tell me how to fix it? Here is the error text:
Arduino: 1.8.5 (Windows 10), Board:"Arduino/Genuine Uno"
AFMotor_Constant Speed 3:50: error: 'val' does not name a type
exit status 1
This report will have more information with
enabled file -> Settings ->
And the text of the sketch :
#define motorAgo 11
#define motorBgo 10
#define motorAbac 9
#define motorBbac 6
int command;
pinMode (motorAgo, OUTPUT);
pinMode (motorBgo, OUTPUT);
pinMode (motorAbac, OUTPUT);
pinMode (motorBbac, OUTPUT);
void goAhead() { // едем вперед
digitalWrite (motorAgo, HIGH);
digitalWrite (motorBgo, HIGH);
digitalWrite (motorAbac, LOW);
digitalWrite (motorBbac, LOW);
void goBack() {// едем назад
digitalWrite (motorAgo, LOW);
digitalWrite (motorBgo, LOW);
digitalWrite (motorAbac, HIGH);
digitalWrite (motorBbac, HIGH);
void stopRobot() { // останавливаемся
void goLeft() { // поворачиваем налево
void goRight() { // поворачиваем направо
val = Serial.read() //The error is here, how to fix it?
switch (command) {
case 'f': goAhead(); break;
case 'b': goBack(); break;
case 's': stopRobot(); break;
case 'l': goLeft(); break;
case 'r': goRight(); break;
val = Serial.read()
not in any function, no semicolon, no datatype given for "val"
A line something like 'void loop() {' somewhere in your code might also help.
Steve
Thank you advice, but now I have another mistake in the same place. Here is the error text:
AFMotor_Constant Speed 4:51: error: expected unqualified-id before 'if'
exit status 1
And text sketch:
#define motorAgo 11
#define motorBgo 10
#define motorAbac 9
#define motorBbac 6
int command;
if (Serial.available() > 0) // The error is here
char command = Serial.read();
switch (command) {
That line of code is not in a function
You can see this clearly if you Auto format the code in the IDE
void goRight() // поворачиваем направо
switch (command)
case 'f':
goAhead();
//etc, etc
